Community Member
CME and ATA Fax
I have ATA using SCCP in my CME for a remote location.
Since im using Fax Passtrough how can i force that calls originated from ATA Port 1 use G711 only.
I tried codec g711u under ephone but got this error:
R2(config-ephone)#codec g729r8 dspfarm-assist
% Invalid input detected at '^' marker.
Hall of Fame Super Gold
Re: CME and ATA Fax
With CME, unless you configure g729 under ephone, g711 (the default) will be used.
Note, by common consensus the the most reliable image for fax with ATA is H.323, but go ahead trying with SCCP and let us know if it works.
Re: CME and ATA Fax
For fax pass-through mode, AudioMode should be set to 0xXXXX0015 for the Phone 1 port of the Cisco ATA, and 0x0015XXXX for the Phone 2 port.
Re: CME and ATA Fax
The ATA only supports fax pass-through in g.711 mode. When the ATA or gateway detects a fax tone, it should upspeed to g.711ulaw regardless of what codec the call originally negotiates at. If it isn't doing this, check the AudioMode and ConnectMode settings via the ATA web config. There's a document on CCO that explains the recommended setting and what the bitmask corresponds to.
FYI, H.323 and MGCP loads are end of engineering, so running SCCP is probably the wise choice if you care about development support.
