Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
CME and conference with maximum sessions to 0
I configured a CME 2811 to establish conferences. When I want to add a phone on the conference I have : "cannot complete conference".
Here the harware inventory :
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811         , VID: V02 , SN: FCZ100172DD
NAME: "2nd generation two port FXO voice interface daughtercard on Slot 0 SubSlot 0", DESCR: "2nd generation two port FXO voice interface daughtercard"
PID: VIC2-2FXO         , VID: V01 , SN: FOC11277BNN
NAME: "3rd generation two port FXS DID voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "3rd generation two port FXS DID voice interface daughtercard"
PID: VIC3-2FXS/DID     , VID: V02 , SN: FOC13513229
NAME: "PVDMII DSP SIMM with one DSP with half channel capcity on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with one DSP with half channel capcity"
PID: PVDM2-8           , VID: V01 , SN: FOC11415G48
I configured the cme :
voice-card 0
 dspfarm
 dsp services dspfarm
sccp local Loopback0
sccp ccm 10.192.255.158 identifier 77 priority 1 version 7.0
sccp
sccp ccm group 1
 bind interface Loopback0
 associate ccm 77 priority 1
 associate profile 2 register conference
dspfarm profile 1 transcode
 codec g711alaw
 codec g711ulaw
 codec g729r8
 maximum sessions 1
 associate application SCCP
dspfarm profile 2 conference
 codec g711ulaw
 codec g711alaw
 conference-join custom-cptone jointone
 conference-leave custom-cptone leavetone
 shutdown
telephony-service
 sdspfarm units 1
 sdspfarm transcode sessions 128
 sdspfarm tag 1 conference
 conference hardware
I can't no shut the profile conference because maximu session is not defined. But the maximum  is 0
CCME(config)#dspfarm profile 2 conference
CCME(config-dspfarm-profile)#maximum sessions ?
  <0-0>  Number of sessions assigned to this profile
Is the DSP allocated for other ressources ?
CCME-QAR#sh voice dsp
DSP  DSP                DSPWARE CURR  BOOT                         PAK     TX/RX
TYPE NUM CH CODEC       VERSION STATE STATE   RST AI VOICEPORT TS ABORT  PACK COUNT
edsp 0001 01 g729r8    0.1 IDLE  50/0/1.1
edsp 0002 02 g711ulaw  0.1 IDLE  50/0/1.2
edsp 0003 01 g729r8 p  0.1 IDLE  50/0/4.1
edsp 0004 02 g729r8 p  0.1 IDLE  50/0/4.2
edsp 0005 01 g711ulaw  0.1 IDLE  50/0/5.1
edsp 0006 02 g711ulaw  0.1 IDLE  50/0/5.2
edsp 0007 01 g729r8 p  0.1 IDLE  50/0/6.1
edsp 0008 02 g729r8 p  0.1 IDLE  50/0/6.2
----------------------------FLEX VOICE CARD 0 ------------------------------
                           *DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND     : (bad)bad    (shut)shutdown  (dpend)download pending
TYPE  NUM CH CODEC        VERSION STATE STATE   RST AI VOICEPORT TS ABRT PACK COUNT
                           *DSP SIGNALING CHANNELS*
C5510 001 01 {flex}        24.3.4 alloc idle      0  0 0/0/0     02    0         38/0
C5510 001 02 {flex}        24.3.4 alloc idle      0  0 0/0/1     06    0         38/0
C5510 001 03 {flex}        24.3.4 alloc idle      0  0 0/1/0     02    0        221/0
C5510 001 04 {flex}        24.3.4 alloc idle      0  0 0/1/1     02    0        150/0
------------------------END OF FLEX VOICE CARD 0 ----------------------------
Thanks for your help
JB
Everyone's tags (1)
3 ACCEPTED SOLUTIONS
Hiyes , you have to increase
yes , you have to increase your PVDM resources to get enough resources to do hardware conference . Your resources is used by Voice-cards 0/0 & 0/1.Can you disable transcode profie as the below:-
shu
no max sessions 1
max sessions ?
Note: keep in your mind , no need for conference hardware if the conference will be between g711 participants "software Conference will be enough", if the conference will be done with other g729 Prticipant so in this time you will need conference hardware.
please rate all useful information
There's no point in having
There's no point in having him disable transcoding, it won't change a thing, he only has half DSP.
A HW CFB with PVDM2 requires the whole DSP for conferencing, unless you give up on using that half DSP for TDM termination and XCODER, and use it for a HW CFB, there's nothing to do here.
You need to buy more DSPs.
java
if this helps, please rate
www.cisco.com/go/pdi
Hi+5 for jamie ,i just asked
+5 for jamie ,i just asked him to disable transcoding because he didnot associate transcoding profile under sccp ccm group . Anyway so you have to purchase PVDM because you have to do hardware conference ..
VIP Gold
Apply below command under
Apply below command under telephony-service and try once.
no conference hardware
Suresh
shu
no max sessions 1
max sessions ?
java
Dear all
Dear all
Greetings
Can someone help me please, I have CME running voice telephone and I would like to use it to run Cisco Telepresence, but I don't know how to do it.
Please support
Best Regards
ART
That is a complete different
That is a complete different topic from the one on this thread, open a new thread for this. And also mention what material have you reviewed.
java
Hello,I disabled the
I disabled the transcode profile. Max session is still at 0-0.
I need to make conference with g729 codec.
Thanks.
jb
Ok, so if i want to make
Ok, so if i want to make conference in G729 (transcode needed so), I need to buy PVDM . Because i don't have enough resource for both conference/transcoding.
How can i calculate it?
Is that right?
Thanks.
JB
Use the DSP calculator online
Use the DSP calculator online, you'll need at least, another half DSP, or a full DSP, depending on how many conferences you want.
java
Hi kindly check the below
kindly check the below link which will access you to DSP calculator which will help you
http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
677
