Community Member
CME and CUE conf on H.323 voice gateway router 2821
I need to configure CME and CUE on cisco 2821 router which is already running as a h.323 voice gateway.Can you give me a link/idea which teaches me the needed gear..
Thanks in advance
shiv
1 REPLY
Hall of Fame Super Gold
Re: CME and CUE conf on H.323 voice gateway router 2821
Just configure normally, using CLI, on the CCA wizards. Certain numbers will be sent with h.323 and that's it, CME doesn't care.
157
