CME and EvalRightToUse
     We have a couple CME's installed a customer site right now (cutting over tomorrow) that are showing:
StoreIndex: 7   Feature: cme-srst                          Version: 1.0
        License Type: EvalRightToUse
        License State: Active, In Use
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 7  weeks 2  days
            Period used: 1  week  1  day
            Transition date: May 14 2012 06:10:53
        License Count: 25/0  (In-use/Violation)
        License Priority: Low
After running around in Circles with Cisco Licensing and Cisco TAC for a week we are now being told that when the evaluation license expires it will automatically become a permenant license.  I am not getting a warm and fuzzy feeling about this (we have been given a few different answers prior to this one), and I am a bit worried about having a couple sites go out of service in 7 weeks.
Searching through the support forums I have seen a few other people posting about this, and being given this same answer, (or a similar answer, some say it becomes Right to Use, some say it becomes a 12 year period, etc.).  I haven't seen anyone confirm this though. I am looking for some confirmation from the community from someone that has seen this transition happen, and hopefully make me a little more comfortable with this answer.
We are running CME 9.0 (IOS 15.2(2)T)
Thank you
    Denis
Everyone's tags (3)
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: CME and EvalRightToUse
Hi Denis,
Here we go my friend. This has been confirmed in our recent use and is also detailed
in the doc below
Activating CME-SRST Feature License
The ISR-G2 comes with a 60-day evaluation license. After 60 days, the license changes to “right to use”.
The customer is required to pay for the CME-SRST feature license which is valid for 12 years.
Prerequisites
• UCK9 license
• ISR-G2 already accepts UC CLIs
SUMMARY STEPS
1. show license detail cme-srst
2. configure terminal
3. license accept end user agreement
4. exit
5. show license detail cme-srst
6. write mem
DETAILED STEPS
Command or Action Purpose
Step 1 show license detail cme-srst
Example:
Router# show license detail cme-srst
Displays the available cme-srst license. EULA should be in NOT
ACCEPTED state.
Step 2 configure terminal
Example:
Router# configure terminal
Enters global configuration mode.
Step 3 license accept end user agreement
Example:
Router(config)# license accept end user
agreement
Configures a one-time acceptance of the EULA for cme-srst
license.
Accepts EULA by typing YES.
Step 4 exit
Example:
Router(config)# exit
Exits global configuration mode.
Step 5 show license detail cme-srst
Example:
ACCEPTED state.
Step 6 write mem
Example:
Router# write mem
Saves configuration.
Command or Action
This is explained in more detail starting on Page 15;
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.pdf
Cheers!
Rob
Hi Denis,
in the doc below
Prerequisites
• UCK9 license
SUMMARY STEPS
4. exit
6. write mem
DETAILED STEPS
Example:
ACCEPTED state.
Example:
Example:
agreement
license.
Step 4 exit
Example:
Example:
ACCEPTED state.
Step 6 write mem
Example:
Router# write mem
Command or Action
Cheers!
Rob
Thanks Rob.  I hadn't stumbled across that doc yet (or if I had I missed that section).  makes me feel a bit better
Hi Denis,
You are always welcome
That portion of the doc was just added recently due to the uncertainty
that the Eval RTU licensing change caused for so many customers.
You're good to go here.
Cheers!
Rob
3639
