CME and gatekeeper
Hi all,
I have 2 cme system in two locations .I want to use one cme router as gatekeeper .And limit calls between the sites to 4 g729 calls .Can any one show how can i do this defining zones?
thanks in advance
Thusharam
1 ACCEPTED SOLUTION
Re: CME and gatekeeper
here is the sample config:
hostnames: cme1, cme2
cme1 (gwgk):
----gk config------
gatekeeper
zone local cme1 domain.com
zone local cme2 domain.com
zone prefix cme1 1...
zone prefix cme2 2...
bandwidth total zone cme1 64 (4x16kbps per call)
bandwidth total zone cme2 64
gw-type-prefix 1#* technology
arq reject-unknown-prefix
-----gw config------
interface loopback 1
ip add
h323-gateway voip interface
h323-gateway voip id cme1 ipaddr
h323-gateway voip h323-id cme1@domain.com
h323-gateway voip tech-prefix 1#
h323-gateway voip bind srcaddr
gateway
(pointing all voip call to gatekeeper)
dial-peer voice 10 voip
destination-pattern 2...
session target ras
Then configure the same gateway config at cme2. replace the following:
id = cme2
h323-id = cme2@domain.com
session target = 1...
Hall of Fame Super Gold
You can do that but I think is really not necessary to configure GK for two sites. Just configure max-conn to 4 under dial-peer.
Ok.But is it cisco best practise ????
Yes. Best practice means doing the most with simplest configuration.
Thanks for the nice rating and good luck!
cme1 (gwgk):
----gk config------
gatekeeper
ip add
gateway
session target ras
id = cme2
thanks . very useful...
I need to set up a CME to CME system with one CME as GK as well. However, I will only be working with ip addresses and will not have DNS available. Do you know what i must do in such a case?
Why is that you want to use GK with just two CMEs ?
This is meant for a lab just to get the concept down. Down the road may use it for larger systems.
251
