Community Member
CME and PABX integration
Hi Guys,
I need to deploy CME at a central site and link it to a PBX at a remote site. Which are the different methods of doing this and the pro`s and cons of each. Also, what hardware would be required and how can i do this....thanks.
1 REPLY
Hall of Fame Super Gold
Re: CME and PABX integration
Hi, the best method would be using BRI or PRI interfaces, you also need programming the PABX and have the ports on them, alternatively you can configure the router to be between PBX and telco lines, this way the PBX does not need any configuration or additional HW.
If you are interest in project guidance,contact me at the address present in my profile.
116
