Community Member
CME and SIP calls through VPN
I have configured CME 4.1 to act as SIP Proxy Server,Configured it corectly so X-Lite SIP Softphone can register with it. Inside LAN network X-Lite to X-Lite calls function without the problem, but:
I connect through VPN to my LAN and register X-Lite with CME (extenssion 66) without any problem.
The other person also connects to our LAN through and registers his X-Lite with CME (extenssion 55).I would like them to talk to each other.
The problem is following. When any of us try to call eachother, the X-Lite Rings, and when a call is answered it immediatly drops with error "Internal Server Error". This is SIP 500 message.
Does anybody has a clue why is this happening and how it can be solved.
regards,
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: CME and SIP calls through VPN
Call from 2222 tries to use an unsupported speex codec. Please configure x-lite to use g711u only.
Have configured codec g711u for the voice pool
Community Member
yes, I have configured it with the command
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
and then under voice poolvalso
voice-class codec 1
Are both phones registered to CME ?
Can you include the full "debug ccsip message" ?
Community Member
Yes,both phones are registered to CME through VPN.
Community Member
I have also to mention following.
When I connect from one location using VPN and registering to CME with IP Communicator and from other Location using VPN and registering X-Lite, calls can be placed between IP Communicator and X-Lite.
The only issue is X-Lite to X-Lite (SIP to SIP) calls
regards
Should not be necessary, but please also configure
voice service voip
allow-connections sip-to-sip
Community Member
have already configured that.
Please send the complete trace.
Community Member
Ok,
I will send it soon
Community Member
here is the trace
Community Member
In X-Lite I have set only G711a and G711u codecs, but it was not working.
When I set only G711u codec it worked.
Thanx very much
I will grade it with 5 ;-)
regards
Great, thanks for the nice rating and good luck!
842
