02-03-2014 10:42 AM - edited 03-16-2019 09:34 PM
Hi guys,
I'm trying to configure a SPA3000 with a CME. I would like the calls from PSTN to go the SPA and then to CME.
I have an analog phone on the SPA. If I call the analog line from PSTN the analog phone rings. That works.
But how could I route the calls to CME? Should I configure a SIP Trunk between the SPA-CME?
Has anybody done this?
Thanks.
Solved! Go to Solution.
02-03-2014 11:49 AM
Hi Stephen,
This would behave like a sip end-point. Add it as a sip-device to the cme.
Sample config:
voice service voip
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
h323
h225 h245-address on-connect
sip
registrar server
voice register global
mode cme
source-address 192.168.4.97 port 5060
max-dn 10
max-pool 10
load 8961 sip8961.9-3-2-10
voicemail 5674
create profile sync 0001087425399153
voice register dn 1
number 1001
voice register dn 2
number 1010
voice register dn 3
number 1003
voice register dn 4
number 1004
voice register dn 5
number 1086
voice register template 2
feature-button 1 DnD
button-layout 1-5 line
button-layout 6-12 feature-button
dialplan 1
session-transport tcp
voice register pool 1
id mac ACA0.16FD.C169
type 8961
number 1 dn 1
dtmf-relay rtp-nte sip-notify
username cisco password cisco
codec g711ulaw
voice register pool 2
id mac A40C.C395.9450
type ata
number 1 dn 2
template 1
dtmf-relay sip-notify
username Cisco password cisco
codec g711ulaw
Let me know if this works.
Kevin
02-03-2014 11:49 AM
Hi Stephen,
Sample config:
voice service voip
h323
sip
registrar server
mode cme
max-dn 10
max-pool 10
voicemail 5674
voice register dn 1
number 1001
voice register dn 2
number 1010
voice register dn 3
number 1003
voice register dn 4
number 1004
voice register dn 5
number 1086
dialplan 1
type 8961
number 1 dn 1
codec g711ulaw
type ata
number 1 dn 2
template 1
codec g711ulaw
Kevin
02-03-2014 12:27 PM
Hi Kevin,
thanks for the info.
I tried but doesn't register.
should I configure something on the SPA? on the Line1, Proxy?
Thanks.
02-03-2014 12:45 PM
Hi Kevin,
got it, the config works.
The SPA registers but if i call from PSTN the analog phone rings.
How can I get it to call a sccp phone that is already registered on the CME?
02-03-2014 01:27 PM
Hi Stephen,
Could you be a little specfic about the way you want to route the calls from the PSTN?
-Kevin
02-04-2014 10:28 AM
Hi Kevin,
I would like to forward all calls from the SPA to a sccp phone which is also registered on the CME.
I tried call-forward b2bua all but doesn't work. is this only for SIP?
Should I change this on the SPA?
Thanks.
02-04-2014 11:55 AM
the call fwd all must be done on the spa. it works now.
problem with audio still, i get noise between the 2 phones...
any idea? codec is the same g711ulaw.
Thanks.
09-28-2015 06:20 PM
I'm trying to configure a SIP trunk between CME and a SPA3000. Calls from the analog phone to VoIP (SIP and SCCP) are working perfectly, but I'm unable to call from the VoIP phones to the PSTN connected on SPA3000.
How have you configured your CME and the SPA300?
Thanks in advance!
