CME - Appending a digit at the beginning of a calling number
Hi!
How can I append a digit at the beginning of a calling number?
I would like users to see in their phones the digit "9" before the calling number when receiving an external call.
Re: CME - Appending a digit at the beginning of a calling number
One option is to use a voice translation rule/profile, such as:
voice translation-rule 1
rule 1 /\(.*\)/ /9\1/
voice translation-profile 1
translate calling 1
dial-peer voice 1 pots
incoming called-number .
translation-profile incoming 1
Hope this helps. If so, please rate the post.
Brandon
Hall of Fame Super Gold
Not to be pedantic :)
Rule above can be rewritten more concisely as:
rule 1 // /9/
This works because the // matches the "null string".
I'm not sure that // works for null. If it does, this rule would replace the string with 9, so you end up with a calling number of 9, not 9 followed by the original calling number.
Brandon
It works :) The match is made on the null string only. The rest of the string, not being matched, is appended unchanged:
ccme#sh voice translation-rule 802
Translation-rule tag: 802
Rule 1:
Match pattern:
Replace pattern: 39
Match type: none Replace type: none
Match plan: none Replace plan: none
ccme#test voice translation-rule 802 5551234
Matched with rule 1
Original number: 5551234 Translated number: 395551234
Original number type: none Translated number type: none
Original number plan: none Translated number plan: none
That was not my understanding of the operation of voice translation rules. I stand corrected.
Brandon
It worked just fine.
Thank you!
149
