CME as SRST Error: returning empty string !!!!
Hi All:
When I configure CME as SRST I get a constant scrolling error: returning empty string !!!!
I cannot find one instance of this error anywhere on the internet. Has anyone ever seen the aforementioned error. Please see the SRST configuration and 'show ephone' output below.
Ron
telephony-service
srst mode auto-provision all
srst dn line-mode octo
max-ephones 10
max-dn 10
ip source-address 177.1.254.3 port 2000
max-conferences 8 gain -6
transfer-system full-consult
secondary-dialtone 0
create cnf-files version-stamp 7960 Oct 30 2013 16:31:32
ephone-dn  1  octo-line
number 3002
description 0207033002
name 0207033002
ephone-dn  2  octo-line
number 3010
description 0207033010
name 0207033010
ephone-dn  3  octo-line
number 3001
description 0207033001
name 0207033001
ephone  2
device-security-mode none
mac-address 001B.D4C6.9372
button  1:1 2:2
ephone  6
mac-address D4A0.2A88.0613
button  1:3 2:2
Branch2#show ephone
ephone-1[0] Mac:-711.-MTP. TCP socket:[19] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 17/12 max_streams=1
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:4
IP:177.1.254.3 61941 Unknown 83  keepalive 0 max_line 0 available_line 0
Preferred Codec: g711ulaw
ephone-2[1] Mac:001B.D4C6.9372 TCP socket:[4] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 11/9 max_streams=0
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:8 privacy:1
IP:177.3.11.17 50124 Telecaster 7960  keepalive 6 max_line 6 available_line 4
button 1: dn 1  number 3002  CM Fallback CH1   IDLE         CH2   IDLE         CH3   IDLE         CH4   IDLE         CH5   IDLE         CH6   IDLE         CH7   IDLE         CH8   IDLE
button 2: dn 2  number 3010  CM Fallback CH1   IDLE         CH2   IDLE         CH3   IDLE         CH4   IDLE         CH5   IDLE         CH6   IDLE         CH7   IDLE         CH8   IDLE         shared
ephone-3[2] Mac:PHQ-.729-.MTP TCP socket:[5] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 17/12 max_streams=1
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:5
IP:177.1.254.1 57397 Unknown 83  keepalive 6 max_line 0 available_line 0
ephone-4[3] Mac:PHQ-.711-.MTP TCP socket:[6] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 17/12 max_streams=1
IP:177.1.254.1 34789 Unknown 83  keepalive 6 max_line 0 available_line 0
ephone-5[4] Mac:-729.-MTP. TCP socket:[13] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 17/12 max_streams=1
returning empty string !!!!nt:0 paging 0 debug:0 caps:0
IP:177.1.254.2 26066 Unknown 83  keepalive 0 max_line 0 available_line 0
ephone-6[5] Mac:D4A0.2A88.0613 TCP socket:[10] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 17/12 max_streams=5
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:12 privacy:1
IP:177.3.11.18 19486 7962  keepalive 4 max_line 3 available_line 3
button 1: dn 3  number 3001  CM Fallback CH1   IDLE         CH2   IDLE         CH3   IDLE         CH4   IDLE         CH5   IDLE         CH6   IDLE         CH7   IDLE         CH8   IDLE
1 REPLY
This issue has been resolved. For some reason, every video example I watched for basic SRST configuration involved deactivating the Callmanager service. I fixed the issue by accident when I was forced to reactivate the Callmanager service because I had to make a call between the Branches and CorpHQ. When I disabled the WAN interfaces
(which of course simulates an actual WAN outage) in lieu of disabling the Callmanager service, the error went away. This also enabled me to make a call from Branch1 running on SRST to Branch2 running on SRST on over the PSTN, however this is on a physical home lab. I believe on the INE lab rack you can only test one branch at a time.
221
