CME B-ACD Nightservice and Huntgroups
hi,
need some help to configure nightservice vs. aa and huntgroups
we have a callmanager express.
Today its configured as follow:
Incoming calls from PSTN are translated to an huntpilot, which is configured with a AA Script.
Look here:
Incoming rule for called numbers from PSTN:
voice translation-rule 2
rule 1 /12340/ /94/
Calls someone from PSTN to 12340 the call is translated to called number 94. Then the scripts work and the caller hears an annoncement, after this
the lines in the huntgroup are called sequential.
The application config:
application
service aa flash:app-b-acd-aa-2.0.0.0.tcl
  param number-of-hunt-grps 1
  paramspace english index 1
  param handoff-string aa
  paramspace english language en
  param max-time-vm-retry 5
  param aa-pilot 94
  paramspace english location flash:
  param second-greeting-time 120
  param call-retry-timer 10
  param max-time-call-retry 600
  param service-name queue
service queue flash:app-b-acd-2.0.0.0.tcl
  param queue-len 10
  param aa-hunt1 95
  param aa-name aa
  param queue-manager-debugs 1
  param number-of-hunt-grps 2
and the huntgroup:
ephone-hunt 1 sequential
pilot 95
list 50, 77
timeout 10, 10
display-logout  logged out from Huntgroup
This works fine.
Now there should be a nightservice. The callers to 12340 should be redirectly immediatly to
an announcement and then the call should be end.
So I configured a nightservice:
telephony-service
night-service day Sun 08:00 07:59
night-service day Mon 17:00 07:59
night-service day Tue 17:00 07:59
night-service day Wed 17:00 07:59
night-service day Thu 17:00 07:59
night-service day Fri 17:00 07:59
night-service day Sat 08:00 07:59
I created a virtual DN:
ephone-dn  55  dual-line
number 90 secondary 49490 no-reg both
description TimeBasedRoutingNumber
call-forward all 94
call-forward night-service 99
night-service bell
Calls goes normal if night service is not active and to DN 99 if night service is active.
Then I changed the translation rule for incoming called number from PSTN pointed to the  new DN:
rule 1 /12340/ /90/
The results:
If night-service active, the call goes right to the extension 99.
If not, the call doesnt route as before, I got an fast busy.
If I do call-forward all 95 at ephone- dn 55 so the call will right go trough the hunt group if night service is not active, but the caller doesnt get the announcement.
Somebody can help?
Hall of Fame Super Gold
For sure results, you can use my B-ACD modifications that support business hours and holiday schedule. Contact info in in my profile.
Hey Support Albakom,
Just came across this thread.
Not sure if you resolved it but if you havent or anyone who will like to do B-ACD with Night Service and a Dummy DN
Please find below
Continue using what you have done pointing the translation rule to 90
Create 2 dial-peers for this purpose and remove service from your main inbound dial-peer
dial-peer voice 23 voip
service app-b-acd-aa
incoming called-number 94
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 24 voip
destination-pattern 94
session target ipv4:
codec g711ulaw
no vad
Please rate the post
Shibly Ibrahim
Please rate the post Shibly Ibrahim
796
