CME-BACD
I have a problem . this is the first time to install CME-BACD . when I finshed the instllation there are an error apper :
Oct 24 06:55:46.027: //3//TCL :/tcl_PutsObjCmd: TCL AA: +++ B-ACD-SERVICE not registered, Starting B-ACD-SERVICE +++
Oct 24 06:55:46.027: //3//AFW_:/AFW_FSM_Drive: Tcl_Eval to drive FSM inside Tcl modulespace. code=1 code=ERROR
Oct 24 06:55:46.027: TCL script failure
        Result:
                         Handoff Failed
Oct 24 06:55:46.027:    TCL script failure errorInfo:
                        Handoff Failed
    while executing
"handoff appl leg_incoming $serviceName -s $hString"
    (procedure "act_Setup" line 37)
    invoked from within
"act_Setup"
My configuration in attached... Please help me
1 ACCEPTED SOLUTION
CME-BACD
Hi Alhassan
please find after update configuration:-
f
dial-peer voice 40 pots
service app-b-acd-aa
incoming called-number 29001
direct-inward-dial
dial-peer voice 2 voip
description Dialpeer to Branches
destination-pattern 2....
session target ipv4:10.x.x.x
codec g711ulaw
application
  param max-time-call-retry 600
  param voice-mail 29003
  paramspace english index 1
  param service-name app-b-acd
  param queue-exit-extension1 29001
  param number-of-hunt-grps 2
  param menu-timeout 6
  param handoff-string app-b-acd-aa
  param dial-by-extension-option 3
  paramspace english language en
  param max-time-vm-retry 2
  param max-extension-length 3
  param aa-pilot 29001
  paramspace english location flash:
  param second-greeting-time 30
  param welcome-prompt en_bacd_welcome.au
  param queue-manager-debugs 1
  param call-retry-timer 10
service app-b-acd
  param queue-len 10
  param aa-hunt1 29006
  param aa-hunt2 29007
Thank you
Please rate all useful information
Hall of Fame Super Gold
CME-BACD
Wrong forum, post in "IP telephony". You can move your posting with the Actions panel on the right.
CME-BACD
thanks paolo for your reply. i already move my discussion ....
CME-BACD
Hi Alhassan
1- You missed the codec g711ulaw on voip dial-peer.
2-you missed dial-peer pots
3- param handoff-string      wrong ( you put aa , where it should be app-b-acd-aa.
4-param service-name      wrong (you put queue , it should be app-b-acd
Thank you
CME-BACD
Hi Alhassan
f
direct-inward-dial
codec g711ulaw
application
service app-b-acd
  param queue-len 10
Thank you
CME-BACD
Dear Islam;
I want to thanks you very much the error is resolved and the script was working well.....
CME-BACD
Hi Alhassan
You are weclome my friend any time , thank you for rating.
thanks
265
