CME, blank in 7914 expansion module LCD
I suspect 7914 LCD broken but want to clarify whether it hardware or configuration issue before initiate RMA.
7961+7914
follows the 7914 module status which occur in sequence when I reset the 7961 phone,
1. all LED Red
2. all LED Amber
3. 1st Green and 2nd Red flashing
4. all LED off
5. Nothing on LCD. should be display the speed dial which configured or horizontal lines but get blank.
follows the CME configuraiton,
tftp-server flash:S00104000100.sbn
telephony-service
load 7914 S00104000100
ephone 73
mac-address 001B.0CDB.D253
username "3974" password 12345
speed-dial 1 1111
speed-dial 2 2222
speed-dial 3 3333
type 7961 addon 1 7914
button 1:142 2:23 3:24 4:25
button 5:26 6:27
Is this RMA issue?
Advise please
Thanks in advance,
Hall of Fame Super Gold
Re: CME, blank in 7914 expansion module LCD
Which FW on the 7961? Can you try latest 8.2(2)SR1 and 5.0(2) on the 7914 ?
Can you try configurin monitor lines instead of speedial (m separator) ?
Dear Sir
i tried them both new version and still problem exist.
thanks
please include output of:
"show run" for the phone in question,
"dir /all",
"show run | inc tftp-server",
and "show run | inc load"
And finally "term mon" and "debug tftp events" when you reset the phone in question.
hello
find the following output:
ephone 3
device-security-mode none
mac-address 001B.5452.0E17
button 1:45 16:71
tftp-server flash:P00307020200.bin
tftp-server flash:P00307020200.loads
tftp-server flash:P00307020200.sb2
tftp-server flash:P00307020200.sbn
tftp-server flash:P00403020214.bin
tftp-server flash:apps11.8-2-2ES1.sbn
tftp-server flash:cnu11.8-2-2ES1.sbn
tftp-server flash:cvm11sccp.8-2-2ES1.sbn
tftp-server flash:dsp11.8-2-2ES1.sbn
tftp-server flash:jar11sccp.8-2-2ES1.sbn
tftp-server flash:SCCP11.8-2-2SR1S.loads
tftp-server flash:term06.default.loads
tftp-server flash:term11.default.loads
tftp-server apps41.8-2-2ES1.sbn
tftp-server cnu41.8-2-2ES1.sbn
tftp-server cvm41sccp.8-2-2ES1.sbn
tftp-server dsp41.8-2-2ES1.sbn
tftp-server jar41sccp.8-2-2ES1.sbn
tftp-server SCCP41.8-2-2SR1S.loads
tftp-server term41.default.loads
tftp-server term61.default.loads
tftp-server flash:music-on-hold.au
tftp-server flash:S00105000200.sbn
tftp-server flash:P00503010100.bin
telephony-service
load 7910 P00403020214
load 7960-7940 P00307020200
load 7914 S00105000200
load 7941 SCCP41.8-2-2SR1S
load 7961 SCCP41.8-2-2SR1S
load 7911 SCCP11.8-2-2SR1S
sh ephone 7914
ephone-3 Mac:001B.5452.0E17 TCP socket:[1] activeLine:0 REGISTERED in SCCP ver 9 and Server in ver 5
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:9
IP:10.102.101.60 51070 7961 sub=3 keepalive 80 max_line 20
Phone reports 6 Available Lines
button 1: dn 45 number 444 CH1 IDLE CH2 IDLE shared
button 16: dn 71 number 470 CH1 IDLE CH2 IDLE
That looks OK.
Please check physical connection with the rj11 cable from sidecar to phone. Also do "config term","telephony-service", "create cnf".
If still doesn't work, then enable "term mon" and "debug tftp event" when you reset the phone, post the output here.
If you do a show flash do you see the file?S00104000100.sbn
Is not said that he would see the firmware file in flash, the sidecar could not have been never upgraded from the router.
What matters, is that both the phone and sidecar run recent firmware, and 4.0(1) is not recent.
688
