CME blocking calls to a specific #
I need to block IP phones from calling a specific list of numbers. What's the best way to do this? I saw that it can be done with translation patterns and also I think it can be done with dial-peers too. The translation pattern way seems elegant enough, but I need to block 100+ numbers and I don't think that translations can handle that many.
Something like this would do the trick, won't it?
Dial-peer voice 100 voip
destination-pattern 912223334444
call-block disconnect-cause incoming call-reject
1 REPLY
Re: CME blocking calls to a specific #
hi!
please use dial-peer cor custom.
syntax:
name
name
then use dial-peer cor list.
syntax:
dial-peer cor list
member
member
where members are the names you declared in dial-peer cor custom.
it is analogous with CSS and Partition:
CSS = dial-peer cor list
Partition = names in dial-peer cor custom
see usage at cisco.com
117
