03-29-2012 05:04 AM - edited 03-16-2019 10:22 AM
I have Cisco CME 8.1
Is it possible to configure
call-forward busy
call-forward noan
only for the incoming external calls
If call within internal phone this should not forward the call.
Is posible to do call forward for only incoming external calls on CME ?
Rgds
Rajesh
Solved! Go to Solution.
03-29-2012 05:18 AM
Hi Rajesh,
Have you tried;
forward local-calls
To allow internal (local) calls to be forwarded, use the forward local-calls command in ephone-dn or ephone-hunt configuration mode. To prevent internal calls from being forwarded, use the no form of this command.
forward local-calls
no forward local-calls
Syntax Description
This command has no arguments or keywords.
Command Default
Internal calls are forwarded as specified in the ephone-dn or ephone-hunt configuration of the called party.
Usage Guidelines
Internal, or local, calls are defined as those calls that originate from other ephone-dns in the same Cisco Unified CME system.
When the no forward local-calls command is used in ephone-dn configuration mode, internal calls to that ephone-dn are not forwarded if the ephone-dn is busy or does not answer. If the ephone-dn is busy, the caller hears a busy signal. If the ephone-dn does not answer, the caller hears a ringback signal. The call is not forwarded even if call forwarding is enabled for the ephone-dn.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_f1ht.html#wp1023323
Cheers!
Rob
03-29-2012 05:18 AM
Hi Rajesh,
Have you tried;
forward local-calls
forward local-calls
Syntax Description
Command Default
Usage Guidelines
Cheers!
Rob
