Community Member
CME Call forward all not showing exact DID
HI,
I have an IP Telephony setup with CME 9.1.
I have an issue with forwarded calls. When I forward the calls(Call forward all) from my IP Phone extension to an external number(Mobile), it shows the board number(Main Number) instead of the DID number. When calls are made directly from the extension(Call forward busy and call forward noan) it shows the exact DID.
I would like the exact DID to be visible for the forwarded call also.
Please let me know the exact command I need to apply on the CME.
Thanks in advance
Nithin Louis.
Community Member
Hi, Any Input guys....
Any Input guys....
Nithin Louis...
Community Member
Hi, think it is a feature
think it is a feature called clip non screening. Have to enabled by the local provider.
Stefam
Hi Nithin Did you use SIP ,
Hi Nithin
Did you use SIP , T1 , E1 , ect...?. Did you do a debug during call forward all ?.
Please rate all useful information
Community Member
Hi Ismal, We are using E1 PRI
Hi Ismal,
We are using E1 PRI connection.
Nithin
51
