CME call get answered but sip phone keeps ringing
asmlicense
Hi all,
When call coming from PSTN, CME registered SIP phone answer the call, but PSTN side phone still keeps ringing. CME is registered to SIP provider.
SIP phone--CME---SIP Provider---PSTN---phone
Here is CME configuration:
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
registrar server
voice register pool-type 8865
phoneload-support
transport tcp
description CISCO SIP PHONE 8865
reference-pooltype 9971
voice register global
mode cme
source-address 192.168.10.1 port 5060
max-dn 10
max-pool 35
authenticate register
timezone 22
tftp-path flash:
create profile sync 0005778351327525
camera
video
auto-register
voice register dn 1
number 1001
voice register dn 2
number 1002
voice register dn 3
number 1003
voice register dn 4
number 1004
voice register dn 5
number 1005
voice register pool 1
busy-trigger-per-button 2
id mac 9C57.ADD2.0EBF
type 7841
number 1 dn 5
username 1001 password 1001
codec g711ulaw
voice register pool 2
id mac 9C57.ADD2.0E78
type 7841
number 1 dn 2
username 1002 password 1002
codec g711ulaw
voice register pool 3
id mac 9C57.ADD2.0EB1
type 7841
number 1 dn 3
username 1003 password 1003
codec g711ulaw
voice register pool 4
id mac 9C57.ADD2.0E9B
type 7841
number 1 dn 4
username 1004 password 1004
codec g711ulaw
voice register pool 5
id mac 94D4.690C.D981
type 8865
number 1 dn 1
username 1005 password 1005
codec g711ulaw
camera
video
voice translation-rule 1
rule 1 /^....$/ /12027981446/
voice translation-rule 2
rule 3 /.*/ /1005/
voice translation-profile INBOUND
translate called 2
voice translation-profile OUTBOUND
translate calling 1
dial-peer voice 22 voip
description Mobile
preference 1
destination-pattern 088.......
session protocol sipv2
session target ipv4:192.168.10.22
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 33 voip
description Mobile
preference 1
destination-pattern 077.......
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1 voip
description International
translation-profile outgoing OUTBOUND
preference 1
destination-pattern .T
session target dns:*******
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2 voip
description Mobile
preference 2
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 3 voip
description Mobile
preference 2
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 100 voip
description Incoming calls
translation-profile incoming INBOUND
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
no vad
sip-ua
credentials username ******* password 7 ******* realm *******
authentication username ******* password 7 *******
nat symmetric role active
nat symmetric check-media-src
registrar dns:*******:5060 expires 3600
sip-server dns:*******:5060
connection-reuse
host-registrar
telephony-service
no auto-reg-ephone
max-ephones 35
max-dn 35
ip source-address 192.168.10.1 port 2000
cnf-file location flash:
max-conferences 8 gain -6
transfer-system full-consult
transfer-pattern .T
create cnf-files version-stamp Jan 01 2002 00:00:00
Please post a "debug ccsip messages" output for the problematic call.
Attached in txt file: debug ccsip messaged and debug voip ccaip all outputs are there.
I tried call from outside, ip phone rang, I answered, but pstn phone still was ringing. Then I ended call in ip phone, but pstn phones was sill ringing.
