CME Call Park Display Timeout
mwadam
Anyone have any idea on how to control the Call Park Display message timeout? Have a requirement to have it stay on the screen until the call is either picked up or disconnected. I have checked all the timers I can come up with and no luck. I am told it is possible in CME.
Thanks!!!
Adam
5 Replies 5
Unfortunately I have read both of these docs several times in the past trying to solve this issue, but to no avail. They only appear to use the timeout command for reminders. No other feature seems to control the display.
Thanks for the input!
Adam
Have you found any solution to this?
Senthil
The only solution I could come up with was to adjust the call park timers so that for example a person would get notified every 10 seconds for 6 time periods for a total of 1 minute. Otherwise there was not any method of keeping the display active.
I figured that one.
Thanks for the reply.
