CME - Call placed on hold, shows back up on Receptionists
phone. If the receptionist transfers (via speed dial button on 7914) a call to someone in the office; and the persons takes the call and places the caller on hold, the call shows back up on the receptionist's phone display. Her phone is NOT configured for "keep-conference" and I tried disabling "transfer full-consult" but this still happens. It is CME 4.0.0(1).
Any ideas?
Thanks.
Mike.
Hall of Fame Super Gold
Re: CME - Call placed on hold, shows back up on Receptionists
Do you mean, it show on the 7914, and NOT on on the other ?
At very least, buttons config please ?
The Manager places his phone on hold (DN on ephone 11) and then that call appears on the receptionist's 7960 display (ephone 10).
Receptionist's EPHONE:
ephone 10
description Reception
mac-address 0019.E8F4.94C3
ephone-template 2
username "d10" password 12345
speed-dial 1 11 label "M. B"
speed-dial 2 12 label "B. R"
speed-dial 3 13 label "L. H"
speed-dial 4 14 label "L. M"
speed-dial 5 15 label "S. "
speed-dial 6 16 label "E. L"
speed-dial 7 18 label "P. R"
speed-dial 8 19 label "J. "
speed-dial 9 20 label "T. "
speed-dial 10 21 label "K. "
speed-dial 11 22 label "K. "
speed-dial 12 23 label "L. C"
speed-dial 13 81 label "After Hours"
speed-dial 14 51 label "Office Closed"
paging-dn 87
type 7961 addon 1 7914 2 7914
mwi-line 4
button 1:82 2:83 3:84 4:10
button 7s11 8s12 9s13 10s14
button 11s15 12s16 13s18 14s19
button 15s20 16s21 17s22 18s23
button 19s17 20s24
Ephone of person who placed the call on hold:
ephone 11
description *** M B ***
mac-address 001A.6D70.C66F
ephone-template 1
username "d11" password 12345
paging-dn 87
type 7941
keep-conference
button 1:11 2o31,64,65,66,67
EPHONE DNs of Receptionists phone:
ephone-dn 82 dual-line
number 82
label Line 1
preference 1
call-forward noan 80 timeout 25
huntstop channel
no huntstop
ephone-dn 83 dual-line
number 82
label Line 2
preference 2
huntstop channel
no huntstop
ephone-dn 84 dual-line
number 82
label Line 3
preference 3
call-forward busy 80
huntstop channel
telephony-service
load 7914 S00104000100
load 7941 TERM41.7-0-3-0S
load 7961 TERM41.7-0-3-0S
load 7936 cmterm_7936.3-3-5-0
max-ephones 42
max-dn 144
ip source-address 192.168.1.1 port 2000
system message
url services http://192.168.1.3/voiceview/common/login.do
url authentication http://192.168.1.3/voiceview/authentication/authenticate.do
time-zone 12
voicemail 53
max-conferences 8 gain -6
moh music-on-hold.au
web admin system name
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern ....
secondary-dialtone 9
after-hours block pattern 3 91268 7-24
after-hours block pattern 4 91284 7-24
after-hours block pattern 5 91340 7-24
after-hours block pattern 6 91345 7-24
after-hours block pattern 7 91441 7-24
after-hours block pattern 8 91473 7-24
after-hours block pattern 9 91649 7-24
after-hours block pattern 10 91664 7-24
after-hours block pattern 11 91758 7-24
after-hours block pattern 12 91767 7-24
after-hours block pattern 13 91784 7-24
after-hours block pattern 14 91787 7-24
after-hours block pattern 15 91809 7-24
after-hours block pattern 16 91868 7-24
after-hours block pattern 17 91869 7-24
after-hours block pattern 18 91876 7-24
after-hours block pattern 19 918887000400 7-24
after-hours block pattern 20 91900 7-24
after-hours block pattern 21 9976 7-24
after-hours block pattern 22 91...976.... 7-24
directory entry 34 25 name Conference Room
create cnf-files version-stamp 7960 Jan 26 2007 17:08:56
on the receptionist's ephone, can you try button 7m11 instead of 7s11, and check if does the same ?
You could also try latest FW 8.0 on the telecaster and latest 5.0 on the sidecars.
167
