CME Call Transfer Issue SIP Trunk
I have a weird issue on a Cisco 2921 router running CME 9.1.
IOS Version: (C2900-UNIVERSALK9-M), Version 15.2(4)M4, RELEASE SOFTWARE (fc2)
Basically the problem is when you transfer a call the call drops after a few seconds. BUT this only happens when an outbound call is placed!
Call Flow:
Extension 1013 --> Calls 90800123123 --> Transfer call to Ext 1014 the call then drops after a few seconds.
You can sometimes get a few seconds of speech in but then the call drops
If for example 0800 123 123 called Extension 1013 and then transferred the call to ext 1014 the call transfers and works fine.
So transfer work for inbound based calls but not when outbound.
Any suggestions greatly appreciated!
Thank You
Adam
Hall of Fame Super Gold
A SIP trace would be needed, however make sure that you have
voice service voip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
That is already present under voice service voip.
The TAC Engineer said that during the outbound call transfer the cme sends a sup update message to the trunk provider which is causing it to fail.
During the incoming call that doesnt happen.
I can do a test call and take debugs. debug ccapit inout and debug ccsip call?
Only debug ccsip message and nothing more.
Re: CME Call Transfer Issue SIP Trunk
find attached.
call flow:
1013 --> calls 07540691598 --> transfer ext 1014
VIP Super Bronze
I have looked at the logs and the problem is how the CCME is trying to perform the transfer. A sip UPDATE method was sent to opensips but their system didnt respond to it..This was sent 4 times..In the past UPDATE/RE-INVITE during call hold/xfer creates issues...
Try and configure mid-call UPDATE consumtion...I an not sure if this will work because it documented to work between a sip to sip CUBE
voice service voip
sip
mid-call signaling block
Sent:
UPDATE sip:+447540691598@208.76.16.106:4080;transport=udp SIP/2.0
Via: SIP/2.0/UDP 31.221.88.178:5060;branch=z9hG4bK2972496
From: "Ext 1013" <>442035881013@sipgw3.orbtalk.co.uk>;tag=12941988-673
To: <>07540691598@sipgw3.orbtalk.co.uk>;tag=MDk6MTE6MTUuMDA
Date: Tue, 30 Jul 2013 09:11:14 GMT
Call-ID: D1E23CE1-F82E11E2-8372B9FC-6A000AE5@31.221.88.178
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M4
Max-Forwards: 70
Route: <193.104.103.6>
Supported: timer,resource-priority,replaces,sdp-anat
Timestamp: 1375175488
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 103 UPDATE
Contact: <442035881013>
Min-SE:  1800
Proxy-Authorization: Digest username="IPT-442035881000",realm="orbtalk.co.uk",uri="sip:+447540691598@208.76.16.106:4080;transport=udp",response="9df45b760de42d64e23f814a7e626592",nonce="83e075aaf872155c41dac0c66dc663a9",opaque="3360477783",algorithm=MD5
Content-Length: 0
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Thanks for the response. I tried but it didnt work.
I captured another log to show:
VIP Super Bronze
Pls send your show run (attach it here)
663
