04-06-2007 06:27 AM - edited 03-14-2019 08:52 PM
Using CME 3.3. Ephone-dn can either be single line or dual-line. When person is on the phone and a second call comes in, call-waiting must ring the phone, not just give the typical beeps. I have tried many combinations of the button 'c' command with multiple ephone-dn's (same number), but always get a beep. How can I make the phone ring for call-waiting while someone is already on a call?
Thanks!!!
Adam
Solved! Go to Solution.
04-06-2007 06:34 AM
Issue the command "call-waiting ring" under ephone-dn configuration.
Hope this helps. If so, please rate the post.
Brandon
04-06-2007 06:34 AM
Brandon
04-06-2007 07:13 AM
Brandon,
Thanks, that did the trick? Guess I couldn't see the forest for the trees.
I appreciate it!
Adam
