Community Member
cme caller id
I have fxo ports plar to autoattendant. Is there a way to pick up the clid and make a decision based on a specific clid that you know is coming in?
Re: cme caller id
There isn't a way to do this.
In theory you could have it plar to a IPCC pilot or some other script, and then that number could take care of it.
But as far as configuring something on the router to take care of this, not as far as I know. There are some IVRs and other things that you can script that would be able to better handle this, but you would still have a simple plar statement on the voiceport that points towards the IVR.
hth,
nick
Hall of Fame Super Gold
Re: cme caller id
Sorry, a decision about what ?
Community Member
Re: cme caller id
If I am running cme, and the plar is for a cme autoattendant, is there a command in the script that allows me to look at the incoming calling number?
Re: cme caller id
The default CUE auto attendant will not look at this. I believe this is something that can be done with custom scripting. I'm not very familiar with custom scripting, but you can do almost anything with custom scripting as long as you have the skills :)
It should be noted that if you want TAC support, they don't support custom scripts.
hth,
nick
140
