CME calls from specific extensions to FXO port
I am having trouble configuring a Cisco 2821 router with CME to send all calls from 3 certain extensions out specific FXO port. I have calls into the router from the PSTN configured to go to extension 840, but I have three phones that I need to have all of their outside calls coming from the phone line plugged into Voice Port 0/1/0. I have tried following the instructions laid out in the following article, but the calls would never trigger the translation patterns.
http://www.cisco.com/en/US/partner/tech/tk652/tk90/technologies_configuration_example09186a00801bc341.shtml
So I followed another tread that suggested using a COR list so I added the following commands to the router.
dial-peer cor custom
     name port010
dial-peer cor list use010
     member port010
dial-peer voice 81 pots
port 0/1/0
destination-pattern 9T
corlist outgoing use010
dial-peer voice 11 voip
     answer-address 840
     corlist incoming use010
dial-peer voice 12 voip
     answer-address 841
dial-peer voice 13 voip
     answer-address 842
However it is still not working correctly.
So how should I configure the router so that all of the outside calls from the extensions 840, 841, and 842 go out Voice Port 0/1/0?
Attached you will find the config from the router for your reference.
Thank you very much,
Michael
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: CME calls from specific extensions to FXO port
For the cor method, apply corlist under ephone-dn, not dial-peer.
Actually, the COR list needs to be applied to both the DN and the dial-peer, otherwise there's no point even having them on for controlling PSTN class of restriction.
The call will succeed if there isn't a COR list on either the incoming or outgoing peer.  The failure scenario is when the incoming COR is a subset of the outgoing COR.  Every other scenario lets the calls through:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
No doubt, but please note in the snipped posted above, the DP's are incoming only, that is the wrong place for COR on CME.
975
