CME cannot answer inbound callwaiting on BRI
neharris
Here's the problem. first call comes in on first line 9481180 and works just fine. then second call comes in on 9481180 and I hear a call waiting tone on the 7970. I see the ANI on the screen pop and the distant end hears ringing. I press the answer key and the first call is placed on hold and I hear about a half second of a busy tone on my end then the call disappears from the 7970. calling party hears continued ringing.
q931 shows
"Requested circuit/channel not available"
I've tried adding secondary LDNs to the spids so that both spids have both numbers. I've tried it without spids, the "cisco recommended" way.
I'm thinking it's a simply configuration issue that I'm blind to so any assistance would be great!
thanks in advance.
11 Replies 11
neharris
Here's the config, I tried to remove all the unrelated meat
version 12.4
network-clock-participate slot 1
no network-clock-participate wic 0
ip dhcp excluded-address 192.168.1.1
isdn switch-type basic-ni
voice-card 1
dsp services dspfarm
voice rtp send-recv
voice service pots
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
h323
voice register global
max-dn 72
max-pool 24
call-history-mib max-size 500
interface BRI1/0
description SBC ISDN BRI 9239481180-2
no ip address
isdn point-to-point-setup
isdn spid1 92594811800101 9481180
isdn spid2 92594811810101 9481181
isdn incoming-voice voice
isdn send-alerting
isdn sending-complete
voice-port 1/1/0
description BRI Card: NM slot 1, port 0 (in use)
dial-peer cor custom
name P-RES-RS
name P-LOC-RS
name P-LD-RS
name P-INTL-RS
name P-UNRES-RS
dial-peer cor list CSS-RES-RS
member P-RES-RS
dial-peer cor list CSS-LOC-RS
member P-RES-RS
member P-LOC-RS
dial-peer cor list CSS-LD-RS
member P-RES-RS
member P-LOC-RS
member P-LD-RS
dial-peer cor list CSS-INTL-RS
member P-RES-RS
member P-LOC-RS
member P-LD-RS
member P-INTL-RS
dial-peer cor list CSS-UNRES-RS
member P-RES-RS
member P-LOC-RS
member P-LD-RS
member P-INTL-RS
member P-UNRES-RS
dial-peer voice 555001 pots
corlist outgoing CSS-LOC-RS
description Pattern=9[2-9]XXXXXX LOCAL 7-DIGIT
destination-pattern 9[2-9]......
port 1/1/0
forward-digits 7
dial-peer voice 555002 pots
corlist outgoing CSS-LD-RS
description Pattern=91[2-9]XX[2-9]XXXXXX LONG DISTANCE
destination-pattern 9[1][2-9]..[2-9]......
port 1/1/0
forward-digits 11
dial-peer voice 555003 pots
corlist outgoing CSS-INTL-RS
description Pattern=9011! INTERNATIONAL
destination-pattern 9[0][1][1]T
port 1/1/0
prefix 011
dial-peer voice 555004 pots
description Pattern=918XX[2-9]XXXXXX TOLL FREE
destination-pattern 9[1][8]..[2-9]......
port 1/1/0
forward-digits 11
dial-peer voice 2 pots
description **BRI pots inbound calls**
incoming called-number .
direct-inward-dial
port 1/1/0
no dial-peer outbound status-check pots
telephony-service
sdspfarm units 4
sdspfarm transcode sessions 2
load 7960-7940 P00308000400
load ATA ATA030100SCCP040211A
load 7961 P00303020214
load 7971 term71.default
max-ephones 20
max-dn 40
ip source-address 192.168.1.1 port 2000
cnf-file location flash:
cnf-file perphone
time-zone 5
time-format 24
date-format dd-mm-yy
max-conferences 1 gain -6
moh music-on-hold.au
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp 7960 Aug 17 2009 00:25:24
ephone-dn 1 dual-line
number 9481180
label 9481180
ephone-dn 2
number 9481181
label 9481181
ephone 1
device-security-mode none
description ETHERNET PHONE 7970G
mac-address 0000.0000.0000
type 7970
auto-line 1
button 1:1 2:2
ephone 2
description ETHERNET PHONE 7971GE
type 7971
auto-line 1
button 1:1 2:2
ephone 3
description IP COMMUNICATOR
username "cupc" password 1717
type CIPC
button 1:1 2:2
ephone 4
description ETHERNET PHONE 7940G
type 7940
no auto-line
button 1:1 2:2
ephone 10
description ANALOG TELEPHONE ADAPTER ata186 port 1
type ata
button 1:1
ephone 11
description ANALOG TELEPHONE ADAPTER ata186 port 2
type ata
button 1:2
It is not a simple configuration, some telco do not provisdion the circuit correctly so that the second call is given directly on the 2nd B-channel, rather they try to use one single B-channel and give call-waiting, the router cannot handle this configuration, either you fixt this at telco level either I don't think anything can be done on the router.
So you're saying that I should be seeing the "Call waiting tone" on B1 instead of B2?
here's the Q931:
First call already in progress on B1
Second call is presented with as call waiting with inband tone and screen pop with ANI
Aug 28 07:03:19.014: ISDN BR1/0 Q931: RX <- SETUP pd = 8 callref = 0x11
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x88
Exclusive, No B-channel
Signal i = 0x07 - Call waiting tone on
Called Party Number i = 0xC1, '9481180'
Plan:ISDN, Type:Subscriber(local)
Locking Shift to Codeset 5
Codeset 5 IE 0x2A i = 0x808001039E05, 'From ', 0x8B0C, '925 855-8569', 0x800101890F, 'Call is waiting', 0x8001048001, '('
Aug 28 07:03:19.074: ISDN BR1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x91
Channel ID i = 0x8A
Exclusive, B2
Aug 28 07:03:19.114: ISDN BR1/0 Q931: TX -> ALERTING pd = 8 callref = 0x91
Channel ID i = 0x8A
Exclusive, B2
When I try to answer the waiting call:
Aug 28 07:03:34.274: ISDN BR1/0 Q931: TX -> CONNECT pd = 8 callref = 0x91
Channel ID i = 0x8A
Exclusive, B2
Aug 28 07:03:34.342: ISDN BR1/0 Q931: RX <- RELEASE pd = 8 callref = 0x11
Cause i = 0x82AC - Requested circuit/channel not available
Signal i = 0x4F - Alerting off
Codeset 5 IE 0x2A i = 0x808001, 'P'
Aug 28 07:03:34.354: ISDN BR1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x91
Aug 28 07:03:34.386: ISDN BR1/0 Q931: RX <- INFORMATION pd = 8 callref = 0xDD
Codeset 5 IE 0x2A i = 0x808001038308, '948-1180', 0x8001098909, 'Connected', 0x80010B8001, '('
Yes, as you can see telco fails to connect 2nd call on B2:
I've been on with ISDN switched support at AT&T for a couple hours now doing various testing and they're saying that the Cisco is not correctly formatting it's call waiting response message on the D-channel. The 5ESS config'd as NI is sending the call waiting without a channel assignment and instead of the Cisco using call waiting it's placing the first call on hold locally (leaving it up connected to the 5E) and is asking for the second call on to be delivered on B2.
Can anyone comment on this? Can Cisco equipment actually use the call waiting feature as it was designed on a single bearer or can it only handle one call per bearer? If everything is as it appears this sounds like a bug
Hi, they're are correct to a certain point, Cisco does not supports call waiting and it can handle only one call per bearer, it is asking the switch to do so but gets a refusal.
I've seen this situation already in various US telcos with BRI, sometimewas resolved by setting on the switch the proper "capability package" see:
http://www.cisco.com/en/US/docs/routers/access/800/801/software/configuration/guide/provisio.html
unfortunately the details are never 100% clear because these are CO things not really divulged to the public.
Thanks for the link but that's for the 700/800's which if I'm not wrong are the old Combinet devices. Not IOS based and very different.
If I have the 5ESS increase the calls per bearer and then the second call to the first number WILL come in on B2 but this is NOT call waiting.
So what you're saying is that Cisco does not support call waiting, It just accepts the call waiting message and asks for the call on another bearer???
Is that what you're saying?
The 800 were true IOS routers and the ISDN logic did not change in this aspect.
Yes the router does not does support call waiting (hold and resume), it specifies the call to be completed on the free bearer, that fails.
I see you all over the forum. Are you paid to answer questions? just curious.
So FYI here is the best solution for anyone with CME and a BRI hanging off of a 5ESS:
how to provision the 5ESS for a BRI with CME
1) disable call waiting
2) set additional call offering to off
3) set CSV (ckt switchefd voice) to 2 for each bearer
4) set total calls to 2
this will produce the following:
-Allows 2 inbound calls on each number if dual-line DNs are configured.
-prevents total of more than 2 inbound calls for the BRI sending a busy tone to caller on 3rd attempt either number (will not see a D-chan msg)
-allows 2 outbound calls on each number
unfortunately cisco does not appear to support call waiting. It receives the call waiting message and instead of allowing the switch to retract the first call and then send the second down the same bearer, it asks the switch to present the call waiting call on another bearer, which is unsupported by the 5ESS (without creating other problems)
I wish Cisco supported call waiting. If they did a BRI on a 5ESS could support up to 16 inbound calls (8 on each spid), DMS100 still only does 2 per bearer
Problem closed.
No I'm not paid. I just answer where I know.
The reason why cisco doesn't support call waiting on BRI or FXO, is that CM/CME are not residential products. Business customers want one circuit per call.
I recently deployed a 27 site mgcp CCM4.2 cluster and one of the sites, in Yuma, AZ was small enough that a PRI was a bad idea. the only other option (supporting multiple DIDs) from Qwest was inbound trunks over h323. Which meant that unless we backhauled calls to another site to gateway out, we had to use POTS for local outbound. 2 BRI's on a 5ESS & call waiting abilities with up to 16 DIDs would've been great solution & less than half the cost and likely less problems. Obviously Cisco would have to support the 5ESS feature sets for multi switched voice calls, call waiting and additional call offering.
I'm suggesting that it's hard to say whether of not business customers would want it or not. Since it's not available there's no statistical opportunity :)
thanks for your comments!
cheers
