CME CDR Customize Accounting Template issue
hi all ,
i have already configured CDR file accounting on my GW Cisco 2811 using FTP server , i can get the file record but i uploaded a template to customize the output attributes , but it's not working.
Notes:
1. Cisco 2811 , with IOS c2800nm-ipvoice_ivs-mz.151-2.T1_2.bin
2. Router configuration :
#gw-accounting file
#acct-template cdr
#primary ftp 192.168.1.24/CDR username cisco password cisco
#maximum buffer-size  40
#maximum retry-count 3
#maximum cdrflush-timer 1
#cdr-format compact
3.
CDR template cdr is running
    url: tftp://192.168.1.4/cdr.cdr
    The last load was successful.
          peer-address
          peer-id
          peer-if-index
Totally 3 attrs defined.
4. the output before apply Template is
1392811331,565,0,1,"390FFC8C 989411E3 86FEDD53 7C448616","104","","12:00:13.123 UTC Wed Feb 19 2014","","12:00:19.033 UTC Wed Feb 19 2014","12:02:11.103 UTC Wed Feb 19 2014","10  ","normal call clearing (16)","answer",0,"",0,0,5599,895840,"104","104","","TWC","02/19/2014 12:00:13.121","104","",0,604,390FFC8C 989411E3 86FEDD53 7C448616,235,"","","",""
1392811331,566,0,1,"390FFC8C 989411E3 86FEDD53 7C448616","922823851","","12:00:16.061 UTC Wed Feb 19 2014","","12:00:19.021 UTC Wed Feb 19 2014","12:02:11.131 UTC Wed Feb 19 2014","10  ","normal call clearing (16)","originate",0,"",5599,940632,5603,896480,"104","104","922823851","TWC","02/19/2014 12:00:16.057","104","922823851",0,605,390FFC8C 989411E3 86FEDD53 7C448616,236,"","","",""
5. the output after applying Template is the same no change after applying template
why there is no change after applying template ????
Hi Hassan,
Detailed records have 123 entries , compact has 22 entries, while filterable are 97 which
you can specify in the custom file.
Other entries are compulsory and would still be present.
So the logic is :
If detailed is selected and custom template is being used , out of 123 you have option to
filter 97 entries.
If compact is being used you have an option to remove the ones present in the list of 97
from the 22 entries present in compact mode.
List of attributes:
These are 97 filterable attributes :
router#sh call accounting-template voice master
       account-code
       acom-level
       backward-call-indicators
       call-id
       calling-party-category
       charge-number
       charged-units
       codec-bytes
       disconnect-text
       early-packets
       faxrelay-start-time
       faxrelay-stop-time
       faxrelay-max-jit-buf-depth
       faxrelay-jit-buf-ovflow
       faxrelay-mr-hs-mod
       faxrelay-init-hs-mod
       faxrelay-num-pages
       faxrelay-direction
       faxrelay-ecm-status
       faxrelay-encap-prot
       faxrelay-nsf-country-code
       faxrelay-nsf-manuf-code
       faxrelay-fax-success
       faxrelay-tx-packets
       faxrelay-rx-packets
       faxrelay-pkt-conceal
       gw-final-xlated-cdn
       gw-final-xlated-cgn
       gapfill-with-interpolation
       gapfill-with-prediction
       gapfill-with-redundancy
       gapfill-with-silence
       gk-xlated-cdn
       gk-xlated-cgn
       gw-rxd-cdn
       gw-rxd-cgn
       gw-collected-cdn
       h323-call-origin
       h323-call-type
       h323-connect-time
       h323-disconnect-cause
       h323-disconnect-time
       h323-gw-id
       h323-remote-address
       h323-setup-time
       h323-voice-quality
       hiwater-playout-delay
       info-type
       incoming-area
       in-carrier-id
       in-intrfc-desc
       in-trunkgroup-label
       internal-error-code
       isup-carrier-id
       late-packets
       logical-if-index
       lost-packets
       lowater-playout-delay
       max-bit-rate
       noise-level
       ontime-rv-playout
       originating-line-info
       outgoing-area
       out-carrier-id
       out-intrfc-desc
       out-trunkgroup-label
       peer-address
       peer-id
       peer-if-index
       redirected-station
       receive-delay
       remote-udp-port
       remote-media-address
       remote-media-udp-port
       round-trip-delay
       service-descriptor
       session-protocol
       subscriber
       transmission-medium-req
       tx-duration
       vad-enable
       voice-tx-duration
       voice-feature
       feature-operation
       feature-op-time
       feature-op-status
       feature-id
       feature-vsa
       dsp-id
       release-source
       alert-timepoint
       ip-phone-info
       ip-pbx-mode
       in-lpcor-group
       out-lpcor-group
       fac-digits
       fac-status
    Totally 97 attributes are filterable.
So according to your configuration, you have used compact and you have defined 3 attributes.
So total attributes will be 25 that you will see in your excel sheet.
Thanks & Regards,
Mudit Mathur
Thanks & Regards, Mudit Mathur
Thanks for your interest
i understand now
515
