Community Member
CME Challenge
Can any one suggest how to implement the below requirement
1) Particular extensions should have option to dial 0 (zero) to call mobile and they should enter password when they dial the zero digit.
Re: CME Challenge
COR + FAC
FAC UC500
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cd45262
The other usual option is as Paolo mentions "use after-hours and PIN login"
Plenty of posts on the matter, if you require more info search NetPro.
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Re: CME Challenge
dont get it can you please post me the links that can help.
125
