CME cisco jabber voice
i have a CISCO2921/K9, i have cisco jabber voice configured and working on iphones,
but all the phones with a voice register pool 13 and above (13 or greater) are not working,
example :
      registration-timer max 720 min 660
      id mac 1100.1100.1113
      session-transport tcp
      type CiscoMobile-iOS
      number 1 dn 13
      dtmf-relay rtp-nte
      username 691 password 691
works but anything above 13, like voice register pool 14 is not working.
any idea?
is this related to license problem, if yes how can i check how many voice pool licenses i have?
How does your config look? Look at the MAX-DN and the MAX-POOL values.
Please see example:
voice service voip
allow-connections sip to sip
!--- Enable SIP to SIP calls.
sip
registrar server expires max 1200 min 300
!--- Enable Cisco IOS SIP registrar.
voice register global
 mode cme
!--- Set Cisco IOS SIP registrar to CME mode.
 source-address 192.168.10.1 port 5060
!--- Set the source address for phone registration.
 max-dn 20
!--- Set max extensions.
 max-pool 10
!--- Set max phones.
 load 7970 SIP7 SIP70.8-2-1S
!--- Specify phone loads for each phone type.
 load 3911 SIP3951.8-0-2-9
 authenticate register
!--- Set authentication for phone registration.
 authenticate realm cisco.com
 tftp-path flash:
!--- Specify path for tftp files.
 create profile
!--- Create configuration files for all phones.
 dialplan-pattern 1 4085251... extension-length 3
!--- Configure dial-plan pattern for the system.
Voice CCIE #37771
Thank you for your reply,
mode cme
source-address 192.168.200.10 port 5060
max-dn 100
max-pool 110
authenticate realm all
hold-alert
tftp-path flash:
file text
create profile sync 0279904409135605
The config is correct as many voice pool register are already working , just any voice pool register 14 or higher are not working, i have a TAC case opened with Cisco and they are checking it, once the case is closed i will updated here.
Thank you very much, well if TAC takes a while then surely it is something more than a license or n config.
Good luck and keep us posted please.
Voice CCIE #37771
While preparing some debugs for the TAC team i found that the flash was full ,
so once i cleared some memory the extra pools worked.
Best regards
275
