CME - Conferencing Problem
I have CME 7.1
Is it a must that for more than two party conf. call I should create OCtal Dn, I created dual-line DN, and the call gets dropped if I want to involve the third party.
thanks
1 REPLY
Green
Re: CME - Conferencing Problem
I wanted to share this link with you:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/
guide/cmeconf.html
Make sure dedicated DSPs available to do hardware conferencing, or
software conferencing are set up either. (If you had intended to do
software conferencing, that link will be helpful).
Phone conferences will only work with dual (or octal) line ephone-dns.
153
