CME Configuration
I had previous posts regarding the problems i'm facing with the CME configuration. Here is the basic CL i made:
tftp-server flash:P00307020200.sbn
tftp-server flash:P00307020200.bin
tftp-server flash:ATA030100SCCP040211A.zup
!** CME TELEPHONY SERVICE Configuration **
telephony-service
no auto-reg-ephone
load 7960-7940 P00307020200
load ATA ATA030100SCCP040211A
max-ephones 48
max-dn 96
calling-number initiator
system message Cisco CME
voicemail 600
max-conferences 8
secondary-dialtone 9
moh music-on-hold.au
service phone videoCapability 1
time-zone 12
date-format mm-dd-yy
network-locale us
web admin system name atlanta secret 0 atlanta
dn-webedit
time-webedit
call-forward pattern .T
call-forward system redirecting-expanded
transfer-system full-consult dss
transfer-pattern 9.T
no call-park system redirect
!** INTERCOM DN Configuration **
!** EPHONE DN and EPHONE Configuration **
ephone-dn 1 dual-line
number 1001
label 1001
name CCO
description CCO
cor incoming user900-international
call-forward busy 600
call-forward noan 600 timeout 15
ephone 1
mac-address 001a.e2bc.8d3f
type 7940
username user1 password 1001
button 1:1
exit
I didn't set up my phone for DHCP, it has a static ip. I don't know if the problem is in this configuration or in the network. The CME and IP phone 7940 are connected to a cisco switch, and to the same vlan. Is there anything i'm missing here?
Silver
Re: CME Configuration
Sorry fella, what exactly is the issue? What isn't the phone doing?
Well after i plugged the phone, i was expecting to see the reload process and the phone getting the configuration and the firmware from the CME, so in the beginning it seemed that it's doing fine, but later it didn't work out and instead the phone got frozen with a "tftp timout" message on the screen.
I tried to reset the phone to default settings without any success. I've been contacting you guys for a week and everybody is telling me to reset it by unplugging the cellphone and again plugging power to it alongside holding down on "#", then push 123456789*0#. Beleive me i did this 10 times at least and the phone is still frozen and i can't even get access to the manual setting. Isn't that weird?
Hall of Fame Super Gold
under telephony-service, you need "ip source-address ...". Put the same address as defined for TFTP in dhcp, that is, an interface active on the router, in the phone vlan if one is used.
Hope this helps, plase rate post if it does!
Silver
"create cnf-files" might also be needed under telephony-service.
Phones might register the first time, but doing a reset or restart in telephone-service might also give tftp-timeout.
705
