cme cor list expert
here is the scenario. I have 3 analog pots lines for inbound and outbound calling. Two of the pots are in a hunt group from the carrier so they ring staff member phones via a plar. the other rings only the ceo. so far so good.
now what they want to happen is this and this is were I need help.
outgoing calls from staff can only use ports 1 and 2
outgoing calls from ceo uses port 3 but if that's busy use port 1 or 2
I can figure out how to have the staff use 1 and 2 and the ceo use port 3 but I can't figure out how to allow ceo to use port 3 then 1 then 2
Hall of Fame Super Gold
Re: cme cor list expert
you can use a mixture of trunk-group and dn trunk, no cor required.
On boss's phone, please configure the uppermost button with an additional extension, label it "external". This button will be used for outgoing and incoming external calls, with the precedence you indicated.
Now, please ask the boss to use the upper button for external calls, no access digit required, calling like from home.
If he doesn't like the idea of using one button for external calls and one for internal ones, I will suggest later a workaround. But, the basic technique is the same:
voice-port 0/1
trunk-group staff
connection plar-opx
voice-port 0/2
trunk-group staff
connection plar-opx
voice-port 0/3
trunk-group boss
connection plar-opx 10A
ephone-dn 10 dual
! External for Boss
number 10A
trunk B
ephone 10
name Boss
button 1:10,2:11
dial-peer voice 10 pots
description for staff use only
destination-pattern 9T
trunkgroup staff
trunkgroup staff
dial-peer voice 20 pots
description for boss
destination-pattern BT
trunkgroup boss 10
trunkgroup staff 20
thanks for your help. you put me on the right track but I used corlist boss for one number and corlist staff for the other, because what I've read about trunk and maybe I'm wrong is that you can't forward or set noan.
Bill
135
