Bronze
CME Cor-list questions!!
CME 3.3.
For example,
User has 7960 with button 1 with extension 8001 single line. Then second button also has 8001 single line.
I assign corlist to ephone-dn 1 with extension 8001 only access to long distance.
Then I assign corlist to ephone-dn 2 with extension 8001 only access to local only.
But I found out that second button is able to call long distance too, it seems like inherit the ability of first button. Is that true??
If that is true, is there other way to workaround. I know I can assign extension 8002 to button 2, it will solve the problem.
Ken
Hall of Fame Super Gold
Re: CME Cor-list questions!!
Config please? COR should definitely respect whatever configuration has been made in the originating ephone-dn. If you are in doubt what is the ephone-dn being used, please enable "term mon" and "debug dialpeer".
Hall of Fame Super Red
Hey Ken,
My understanding of this feature is that what you have discovered is working as designed. The Cor parameter is applied per unique ephone-DN. So that means that you cannot have two diffent Restriction levels on the same number (in this case 8001). Have a look at these good docs;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00804ad857.html
Configuring Class of Restrictions (COR)
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
Hope this helps!
Rob
Hi Rob,
I think that what Ken is saying, he has two separate ephone-dn (buttons in his terminology) with the same number (8001), and these are configured with different corlist. That is why I've asked for the configuration to clarify.
409
