CME/CUCM - Can you set a ringtone based on ANI
I have a small client with CME.  They have two POTS lines that ring inbound as the 2nd and 3rd line on every phone in the building.  They occasionally get priority calls from a specific external caller, all of which will originate from the same number.  They are asking if they can get a distinctive ring tone for when a call comes in from that number.  I know you can set internal/external ring tones but is there any way to tie a specific ring to a specific ANI?  I can't find a way in the documentation.
Just out of curiosity, can you do this in a standard CUCM implementation?
1 ACCEPTED SOLUTION
Answer is no on both systems.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
1 REPLY
java
java
311
