Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
CME & CUE AA Issue
I currently have a CME install with a CUE module.  We are using the AA for basic call routing.  We have one issue. When we dial the main number it always goes the AA.   There is a generic greeting and you can dial an extension at anytime to reach your party.   However, sometimes when you dial the 2 digit extention you get "are you still there"   It is like it does not recognize the DTMF digits.   It then re-cycles through the greeting and then if you hit the same 2 digit extension again it works.
Has any experience this issue??   Thanks!!
Re: CME & CUE AA Issue
How are the digits coming in?  Where are they coming in from?  PRI?  ITSP SIP trunk?  And how are you configured for DTMF to CUE--is it SIP notify, or RTP-NTE?  More details will let me guide you in what you need to specifically look at.
Likely, you'd want to get debugs, or if possible better would be a packet capture.  Some of the digits may not be coming within proper specification.  Or there could be in-band leakage in the audio stream causing duplicate digits.
If it is a PRI, make sure you don't have excessive input gain on the port, for starters.
Plain ol' 'debug voip ccapi inout' will let you see DTMF being detected on the ingress leg.  You can look for missing or duplicate digits there, at least letting you do problem isolation.  Once you respond with the protocols being used, I can let you know more specific debugs to look at on each leg.
-Steve
Bronze
Hi, also check if you have configured these commands in your CME.
voice service voip
  allow-connections h323 to SIP
allow-connections SIP to h323
David
David: The 'allow-connections' statements wouldn't cause this issue with DTMF which is being reported by the original poster.  The call would not connect to CUE at all if those commands were an issue.  They have nothing to do with DTMF-relay negotiation.
199
