CME-CUE Sync Issue
I am trying to give the hostname, webusername and password of cme in a freshly built cue. But the cue is not acceppting it. It pops up an error message asking to check the cme configuration.
I have attached screen shot of error and show run command. Kinldy take a look.
Thanks in advcance.
Fawaz Khan
Hall of Fame Super Gold
CME-CUE Sync Issue
And you can access via web using the same credentials ?
Because if you can, there is no reason why CUE shouldn't.
Anyway, I found the sync feature of CUE to have many limitations. I'm now using custom script to generate both CME and CUE config from cals cutsheets, exported to CSV.
CME-CUE Sync Issue
yes I am able to login to both cme and cue via web.
CME-CUE Sync Issue
You can try debug ip http server on the CME.
CME-CUE Sync Issue
Under Administration> Syncronize Information in CUE I get this error too..
Error: Unable to login as administrator to the CUCME at site  'local'.
Details: Login failed. Hostname not configured.
CME-CUE Sync Issue
It is solved now. I made edited the configuration.
Earlier I had given
ip http path flash:
Now i changed tat to
ip http path flash:/GUI
So web issue is not there.
Thank Paolo for taking time and giving me ideas..
CME-CUE Sync Issue
Very good, please remember to rate useful posts clicking on the stars below.
948
