CME/CUE voicemail to email
I believe the answer is no, but thought i would check anyway. Is there a way to have voicemails deleted automatically after they have been deleted from the email.
cue 3.0.
thanks.
Re: CME/CUE voicemail to email
What you are looking for is the IMAP feature for cue.. check out this link..
https://www.myciscocommunity.com/docs/DOC-1445.pdf;jsessionid=52858FAECF9B8DCF6BE2AD99E43897FA
If this helps, please rate post...
Hall of Fame Super Gold
My understanding is that the OP has that already and wants a way to delete messages via IMAP.
A very reasonable desire, personally I've found the CUE implementation of IMAP to be so flaky that I don't pitch it much to customers.
If you connect the client directly to the CUE Imap server deleting it at that point will delete it from the module.
If you do the exchange integration with IMAP buy using exchange to mediate the notification deleting it in that configuration will not delete it from the module.
Thanks for the helpfull info.
299
