CME/CUE
Dear All,
I m running CME version 7.0 and CUE version 2.1.
My question is that does CME v7 is compatible with CUE v 2.1.
As i m not able to access my CUE through GUI.
Malik.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: CME/CUE
Hi Malik,
Sorry about that my friend! It should be;
Table 1: Cisco Unity Express: Unified CM Express and Unified SRST Versions
Not Table #2
Cheers!
Rob
Re: CME/CUE
i think you need post your CME configuration.
they are compatible.
Re: CME/CUE
Hi Malik,
This document does not show support for CUE 2.1 with CME 7.0;
Cisco Unity Express Compatibility Matrix (Check Table #2)
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/compatibility/cuecomp.htm
Hope this helps!
Rob
Re: CME/CUE
Hi Rob,
Thanks for you reply...but when i see in table #2 its a comparison between CM and CUE not between CME and CUE...so can you plz advise...
Malik.
Re: CME/CUE
Hi Malik,
Not Table #2
Cheers!
Rob
148
