03-03-2014 12:16 PM - edited 03-16-2019 09:59 PM
For most incoming calls coming in on FXO lines we are noticing that there is a 8-10 seconds delay before the audio is established. Call comes in, IP phone rings, then there is 8-10 second delay before either party can hear anything. GW was rebooted and there has been no recent changes.
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 15.1(4)M6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 14-Feb-13 04:14 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
shredit-ottawa-2853511 uptime is 2 weeks, 5 days, 22 hours, 10 minutes
System returned to ROM by reload at 17:01:24 EST Tue Feb 11 2014
System restarted at 17:03:15 EST Tue Feb 11 2014
System image file is "flash:c2800nm-advipservicesk9-mz.151-4.M6.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2821 (revision 4.0) with 473088K/51200K bytes of memory.
Processor board ID FTX0948A2RX
2 Gigabit Ethernet interfaces
1 Serial interface
2 terminal lines
1 Virtual Private Network (VPN) Module
12 Voice FXO interfaces
1 cisco service engine(s)
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO2821 FTX0948A2RX
Please let me know if anyone has encountered this issue or has any troubleshooting steps. If more information is required let me know.
AK
03-03-2014 12:44 PM
please post gw configuration... did it just start out of nowhere?
Chad
03-03-2014 12:46 PM
AK,
Do you have "caller-id" enabled on the FXO port and if you do, does your carrier have caller-id enabled for you. If your carrier doesn't have caller-id enabled for you, calls will take 2 rings before the phones starts ringing. Solution is to remove "caller-id" or pay for the services.
Yosh
03-03-2014 01:10 PM
Thanks for your reply Yosh, we do have caller-id enabled it is a service we have enabled with telco. However the phone rings correctly, once the handset is picked up, there is a 8-10 second delay befire either side can hear anything. Below is the show run requested by Chad.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.03.03 16:00:52 =~=~=~=~=~=~=~=~=~=~=~=
Warning! DSPs1,2 in slot 0 are using non-default firmware from flash:
This is not recommended, the default version is 28.3.9
Current configuration : 40628 bytes
version 15.1
service tcp-keepalives-in
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
service sequence-numbers
boot-start-marker
boot system flash:c2800nm-advipservicesk9-mz.151-4.M6.bin
boot system flash:c2800nm-advipservicesk9-mz.124-3d.bin
boot-end-marker
logging buffered 500000
no logging console
enable secret 4 jHPDLZDous9V1U8vULDXrH1n.MLtRb2ON6oeuKbRZ.I
aaa new-model
aaa session-id common
memory-size iomem 10
clock timezone EST -5 0
clock summer-time EST recurring
dot11 syslog
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.7.3.129 10.7.3.134
ip dhcp excluded-address 10.7.3.251 10.7.3.255
ip dhcp excluded-address 10.7.3.1 10.7.3.19
ip dhcp excluded-address 10.7.3.121 10.7.3.128
ip dhcp pool voice
network 10.7.3.128 255.255.255.128
default-router 10.7.3.129
option 150 ip 10.7.3.129
lease 3
ip dhcp pool data
network 10.7.3.0 255.255.255.128
dns-server 10.2.2.10 10.2.2.11
domain-name
option 189 ascii "10.2.0.111"
lease 3
no ip domain lookup
ip domain name
no ipv6 cef
voice-card 0
interface GigabitEthernet0/0
description Trunk interface to switch - carry voice and data VLANs
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
description Data interface
encapsulation dot1Q 10
ip address 10.7.3.111 255.255.255.128
no ip redirects
no ip unreachables
interface GigabitEthernet0/0.20
description Voice subinterface
encapsulation dot1Q 20
ip address 10.7.3.129 255.255.255.128
no ip redirects
no ip unreachables
interface Service-Engine0/0
description Cisco Unity Express Module
ip unnumbered GigabitEthernet0/0.20
service-module ip address 10.7.3.130 255.255.255.128
service-module ip default-gateway 10.7.3.129
interface GigabitEthernet0/1
bandwidth 10000
ip address 152.192.140.94 255.255.255.252
duplex full
speed 10
service-policy output shape-etm
interface Async0/0/0
no ip address
encapsulation slip
dialer in-band
router bgp 1
bgp log-neighbor-changes
redistribute connected
neighbor 152.192.140.93 remote-as 65000
ip forward-protocol nd
ip http server
no ip http secure-server
ip http path flash:
ip route 0.0.0.0 0.0.0.0 10.100.186.109
ip route 10.7.3.130 255.255.255.255 Service-Engine0/0
tftp-server flash:CP7902060000SCCP050124A.sbin
tftp-server flash:CP7905060000SCCP050124A.sbin
tftp-server flash:CP7905060000SCCP050124A.zup
tftp-server flash:CP7912060000SCCP050124A.sbin
tftp-server flash:P00307020200.bin
tftp-server flash:P00307020200.loads
tftp-server flash:P00307020200.sb2
tftp-server flash:P00307020200.sbn
tftp-server flash:S00104000100.sbn
tftp-server flash:cmterm_7920.4.0-02-00.bin
tftp-server flash:ATA030204SCCP090202A.zup
control-plane
voice-port 0/1/0
input gain 3
echo-cancel coverage 32
cptone CA
connection plar opx 70301
description 123-1231234
caller-id enable
voice-port 0/1/1
input gain 3
cptone CA
caller-id enable
voice-port 0/1/2
no battery-reversal
input gain 3
cptone CA
connection plar 70301
caller-id enable
voice-port 0/1/3
input gain 3
cptone CA
caller-id enable
voice-port 0/2/0
input gain 3
cptone CA
caller-id enable
voice-port 0/2/1
input gain 3
cptone CA
caller-id enable
voice-port 0/2/2
input gain 3
cptone CA
caller-id enable
voice-port 0/2/3
input gain 3
cptone CA
caller-id enable
voice-port 0/3/0
input gain 3
cptone CA
connection plar opx 70353
caller-id enable
voice-port 0/3/1
input gain 3
cptone CA
caller-id enable
voice-port 0/3/2
input gain 3
cptone CA
caller-id enable
voice-port 0/3/3
input gain 3
cptone CA
caller-id enable
mgcp profile default
dial-peer voice 9980101 pots
preference 9
destination-pattern 9T
incoming called-number .
direct-inward-dial
port 0/1/0
dial-peer voice 9980102 pots
description Match 10-digit local calls with no delay
preference 9
destination-pattern 9[2-9].........
port 0/1/0
forward-digits 10
dial-peer voice 9980103 pots
description Match 11-digit NANP Local or LD with no delay
preference 9
destination-pattern 91[2-9].........
port 0/1/0
forward-digits 11
dial-peer voice 9980104 pots
description Match 911 emergency with no delay
preference 9
destination-pattern 9911
port 0/1/0
forward-digits 3
dial-peer voice 9980111 pots
preference 8
direct-inward-dial
port 0/1/1
dial-peer voice 9980112 pots
preference 8
port 0/1/1
forward-digits 10
dial-peer voice 9980113 pots
preference 8
port 0/1/1
forward-digits 11
dial-peer voice 9980114 pots
preference 8
port 0/1/1
forward-digits 3
dial-peer voice 9980121 pots
preference 7
direct-inward-dial
port 0/1/2
dial-peer voice 9980122 pots
preference 7
port 0/1/2
forward-digits 10
dial-peer voice 9980123 pots
preference 7
port 0/1/2
forward-digits 11
dial-peer voice 9980124 pots
preference 7
port 0/1/2
forward-digits 3
dial-peer voice 9980131 pots
preference 6
direct-inward-dial
port 0/1/3
dial-peer voice 9980132 pots
preference 6
port 0/1/3
forward-digits 10
dial-peer voice 9980133 pots
preference 6
port 0/1/3
forward-digits 11
dial-peer voice 9980134 pots
preference 6
port 0/1/3
forward-digits 3
dial-peer voice 9980201 pots
preference 5
direct-inward-dial
port 0/2/0
dial-peer voice 9980202 pots
preference 5
port 0/2/0
forward-digits 10
dial-peer voice 9980203 pots
preference 5
port 0/2/0
forward-digits 11
dial-peer voice 9980204 pots
preference 5
port 0/2/0
forward-digits 3
dial-peer voice 9980211 pots
preference 4
direct-inward-dial
port 0/2/1
dial-peer voice 9980212 pots
preference 4
port 0/2/1
forward-digits 10
dial-peer voice 9980213 pots
preference 4
port 0/2/1
forward-digits 11
dial-peer voice 9980214 pots
preference 4
port 0/2/1
forward-digits 3
dial-peer voice 9980221 pots
preference 3
direct-inward-dial
port 0/2/2
dial-peer voice 9980222 pots
preference 3
port 0/2/2
forward-digits 10
dial-peer voice 9980223 pots
preference 3
port 0/2/2
forward-digits 11
dial-peer voice 9980224 pots
preference 3
port 0/2/2
forward-digits 3
dial-peer voice 9980231 pots
preference 2
direct-inward-dial
port 0/2/3
dial-peer voice 9980232 pots
preference 2
port 0/2/3
forward-digits 10
dial-peer voice 9980233 pots
preference 2
port 0/2/3
forward-digits 11
dial-peer voice 9980234 pots
preference 2
port 0/2/3
forward-digits 3
dial-peer voice 998001 voip
description CUE
destination-pattern 7030[0-7]
session protocol sipv2
session target ipv4:10.7.3.130
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 9980301 pots
preference 9
direct-inward-dial
port 0/3/0
dial-peer voice 9980302 pots
preference 9
port 0/3/0
forward-digits 10
dial-peer voice 9980303 pots
preference 9
port 0/3/0
forward-digits 11
dial-peer voice 9980304 pots
preference 9
port 0/3/0
forward-digits 3
dial-peer voice 9980311 pots
preference 8
direct-inward-dial
port 0/3/1
dial-peer voice 9980312 pots
preference 8
port 0/3/1
forward-digits 10
dial-peer voice 9980313 pots
preference 8
port 0/3/1
forward-digits 11
dial-peer voice 9980314 pots
preference 8
port 0/3/1
forward-digits 3
dial-peer voice 9980321 pots
preference 7
direct-inward-dial
port 0/3/2
dial-peer voice 9980322 pots
preference 7
port 0/3/2
forward-digits 10
dial-peer voice 9980323 pots
preference 7
port 0/3/2
forward-digits 11
dial-peer voice 9980324 pots
preference 7
port 0/3/2
forward-digits 3
dial-peer voice 9980331 pots
preference 6
direct-inward-dial
port 0/3/3
dial-peer voice 9980332 pots
preference 6
port 0/3/3
forward-digits 10
dial-peer voice 9980333 pots
preference 6
port 0/3/3
forward-digits 11
dial-peer voice 9980334 pots
preference 6
port 0/3/3
forward-digits 3
dial-peer voice 999999 pots
destination-pattern 91231231234
port 0/1/0
forward-digits 11
telephony-service
max-ephones 48
max-dn 144
ip source-address 123-1231234 port 2000
timeouts interdigit 5
load 7914 S00104000100
load 7902 CP7902060000SCCP050124A
load 7905 CP7905060000SCCP050124A
load 7910 P00403020214
load 7912 CP7912060000SCCP050124A
load 7920 cmterm_7920.3.3-01-08
load 7935 P00503010100
load 7960-7940 P00307020200
load 7970 TERM70.7-0-1-0s
load 7971 TERM70.7-0-1-0s
load ata ATA030100SCCP040211A
voicemail 70300
max-conferences 6 gain -6
call-forward pattern .T
dn-webedit
transfer-system full-consult
transfer-pattern .......
transfer-pattern ..........
transfer-pattern ...........
after-hours block pattern 1 91010 7-24
after-hours block pattern 2 91900 7-24
after-hours block pattern 5 91242 7-24
after-hours block pattern 6 91246 7-24
after-hours block pattern 7 91264 7-24
after-hours block pattern 8 91268 7-24
after-hours block pattern 9 91284 7-24
after-hours block pattern 10 91340 7-24
after-hours block pattern 11 91345 7-24
after-hours block pattern 12 91441 7-24
after-hours block pattern 13 91473 7-24
after-hours block pattern 14 91649 7-24
after-hours block pattern 15 91664 7-24
after-hours block pattern 16 91758 7-24
after-hours block pattern 17 91767 7-24
after-hours block pattern 18 91784 7-24
after-hours block pattern 19 91787 7-24
after-hours block pattern 20 91809 7-24
after-hours block pattern 21 91829 7-24
after-hours block pattern 22 91876 7-24
after-hours block pattern 23 91868 7-24
after-hours block pattern 24 91869 7-24
after-hours block pattern 25 91939 7-24
create cnf-files version-stamp 7960 Dec 21 2012 14:35:11
ephone-template 1
softkeys idle Newcall Redial Pickup Dnd Gpickup
softkeys seized Endcall Gpickup Pickup Redial
softkeys alerting Acct Callback Endcall
softkeys connected Hold Endcall Trnsfer Acct Confrn Flash
l
scheduler allocate 20000 1000
ntp update-calendar
ntp server 206.112.194.76
ntp server 206.112.202.76
end
03-04-2014 10:21 AM
Is this a new setup? If not, how long has this issue been occuring for? Can you give an example of which number is dialed and the ephone-dn or dial-peer that the call goes to?
Yosh
03-04-2014 11:14 AM
Hi.
Can you please activate a debug vpm all and capture the output during a call?
Carlo
