CME- Dial out problem with corlist
Hi All;
I have CME configured with cor. I have two dial-peer one for International access and other for national access as shown below.
**International access**
dial-peer voice 21 pots
corlist outgoing International
preference 2
paramspace callsetup after-hours-exempt TRUE
destination-pattern 8.T
incoming called-number .
direct-inward-dial
port 0/0/0:15
other one is
** Nationla access***
dial-peer voice 20 pots
corlist outgoing National
preference 1
destination-pattern 9.[1-9]T
direct-inward-dial
port 0/0/0:15
Most of the things works fine axcept the national numbers not internation with second digit zero (0) like i 6054532 and 9054532, 802066. I ma using 9 to dial out and to dial international i am using 8 to dial out. In pots dial-peer voice 20 i have destibation pattern 9.[1-9]T for national calls.I dont know how router CME blocking only calls with second digit zero not including 9 to dial out. rest is working fine.
waiting for your reply.
1 REPLY
Hall of Fame Super Gold
Re: CME- Dial out problem with corlist
try making you DP more specific and the problem should go away. eg:
destination-pattern 900[1-9]......T
prefix 00
destination-pattern 9[x-y]....T
replace x and y above with the valid range of digits for national calls. In the example 9 is used for all calls, as for COR to work is not necessary that you use separate digits.
177
