Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Bronze
CME Dial Peer beginning with *
Hi All,
We have a site where there are now lots of in country external numbers beginning with either 3 or 4 digits which begin with a * (e.g *234 or *4567 etc..). Can this be incorporated into a dial peer beginning with * or do I need to implement this in a different way?
Re: CME Dial Peer beginning with *
Yes, you can have a destination-pattern which begins with an *, however, you cannot do two **.
For two ** you would need to use num-exp \*\* instead.
Examples for *8 on a voip DP, *9 on a POTS DP and finally a **3 which routes to 916125551212:
num-exp \*\*3 916125551212
dial-peer voice 1 voip
destination-pattern *8
dial-peer voice 2 pots
destination-pattern *9
dial-peer voice 3 pots
destination-pattern 91[2-9]..[2-9]......
Anthony Holloway
Please use the star ratings to help drive great content to the top of searches.
Anthony Holloway
Bronze
I have the following and doing some testing but the call is failing.
dial-peer voice 50 pots
corlist outgoing callnational
tone ringback alert-no-PI
description NumbersStartingWith*
destination-pattern 9*T
progress_ind progress enable 8
port 0/0/0:15
prefix *
If I dial 9*8080 (which is one of the in country numbers - 8080) I get message from the telecom provider saying incorrect number basically.
If I want to dial *8080 over my pots line should the above peer work or am I missing something?
If you are sending the * to the telecom provider, then you need to know if that is acceptanble or not.
Also, what does the command show for you with that configuration:
show dialplan number 9*8080
Anthony Holloway
Anthony Holloway
Bronze
if I do the following -
I'm assuming it woul be 9*8080 as they need to press 9 for outside line.
CCME-01#sho dialplan number 9*8080
Macro Exp.: 9*8080
No match, result=1
It doesn't seem to be matching my dial peer below.
port 0/0/0:15
prefix *
My apologies, I typed an 8 by mistake when I meant to type a 9.  I have corrected it above.
Also, the T is what's messing you up.  You would have to do 9*8080 or even 9*....
Anthony Holloway
Anthony Holloway
Silver
Just change your destination-pattern to "9\*T" so the "*" will be treated as a digit rather than a wildcard.
That doesn't work on 15.1(4)M1 Brian.  Do you have a version it does work on?
VoiceRouter(config-dial-peer)#destination-pattern 9\*8080
Incorrect format for E.164 Number
        regular expression must be of the form  ^[][^0-9,A-F#*.?+%()-]*T?(\$)?$
Anthony Holloway
Anthony Holloway
Bronze
Hi Guys,
Yeah Brian that's not available on our CME Version.
Anthony - The reason I cannot do 9*.... is that there have hundreds of numbers beginning * but some have 3 digits, some have 4. Meaning if I use 9*.... it's always going to wait for the 4th digit. So I can't dial 3 digits using this way.
Also I can't have two dial peers, one with 9*... and 9*.... as the first one will always get matched (3 digits) meaning the site won't be able to dial the 4 digit numbers beginning with *
Must be a way to do this :-)
Variable length dialplans are always problematic.
This works instead of the T for both 9* + 3 digits and 9* + 4 digits
destination-pattern 9*....?
The ? on the end is entered by pressing CTRL+v first, then ?, otherwise you'll just end up pulling up the help.
And the ? says "zero or one of the preceeding".  Meaning the last digit is optional.
EDIT: Re-read my command and I was one dot short.  Was 3, now it has 4.  Sorry for the confusion.
Anthony Holloway
Anthony Holloway
Bronze
Hi Anthony,
Have amended the destination-pattern to 9*....? as advised and now when dialing a 4 digit number, e.g 9*8080
It is dropping the last digit so only *808 is being dialled. Means I can't dial 4 digits number..
Mystery continues...
I see you were using prefix *.  What if you chaged this to forward-digits 5?
Anthony Holloway
Anthony Holloway
Bronze
Just to update on this guys. It turns out the telco provider at that site doesn't actually support the * short dial until they upgrade their own switches in their telecom network. I think the office thought it was standard across the whole PSTN there. So no matter what I done, it wouldn't have worked. The telco are looking to have their infrastructure upgraded in the next week or so. Once done, I will confirm the provided solutions are working or not.
Thanks All.
Bronze
Hi Guys,
Reviving an old one here. The Telco updated their systems so numbers beginning with *xxx and *xxxx can be dialled from standard telephones across the PSTN.
I have added the following Dial Peer on our CME to test - but when dialling either 9*9000 or 9*9090 the calls do not connect.
Am I missing something here?
Just to recap on this - There are PSTN numbers now begnning with * symbol and I'm trying to be able to dial these from Cisco phones. We use 9 for outside line. I added dial peers for 2 specific *xxxx numbers to test but they do not work.
They DO work from a standard analogue phone.
dial-peer voice 10 pots
preference 1
destination-pattern 9*9000
direct-inward-dial
port 0/0/0:15
prefix *
dial-peer voice 20 pots
destination-pattern 9*9090
progress_ind setup enable 3
direct-inward-dial
port 0/0/0:15
prefix *
A POTS dial-peer will digit strip by default. This means, starting from the left of the number, it will strip all explicitly typed characters from your destination pattern.
In your case, that's all digits.
While you are doing a prefix *, that will simply send an * to the telco, nothing else.
You can simply change your prefix to *9000 and prefix *9090 respectively and test.
Also, do a debug isdn q931 to see what digits you are sending.
Anthony Holloway
Anthony Holloway
730
