Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
CME Dial Peer Stripping First Digit
          I have 2 site SITE A with CUCM 9.2 with the extension numbers 9XXX and I wan to call from SITE B which has CME . To do this I created Inter cluster trunk on the CUCM9.0 and created dial peer on CME  to receive the call and works perfectly.
The CME site users uses digit 9 to take external line to call on mobile or land lines.
When I make a dial peer with destination pattern 9... it works but they are not able to take external line since 9 is already used.  I want a dial peer like this listed below
destination pattern 29xxx where it should strip first digit 2 and send 9xxx.
1 ACCEPTED SOLUTION
voice translation-rule 1 rule
 rule 1 /^2\(9...$\)/ /\1/
voice translation-profile Strip2
 translate called 1
dial-peer voice xxx voip
 translation-profile outgoing Strip2
Manish
 translate called 1
Manish
Thanks Manish will it work
Thanks Manish will it work like this
voice translation-rule 9000
 translate called 9000
dial-peer voice 9001 voip
destination-pattern 2[9]...
session target ipv4:10.202.0.3
dtmf-relay h245-alphanumeric
 no vad
VIP Gold
yes, it will work. Suresh
yes, it will work.
Suresh
Thanks Manish it worked
Hi Mansih,I was just thinking
Hi Mansih,
I was just thinking will this work or not, Could please let me know.
dial-peer voice 123 voip
destination pattern 29XXX
digit forward 4
session target ipv4 x.x.x.x
Thanks in advance
I haven't tried forward digit
I haven't tried forward digit on VOIP dial-peer because translation profile is more powerful tool to manage digits.
If it something new to new IOS then it will works same as on POTS dial-peer and Yes it will forward only last four digits.
Manish
Hi Manish, Thanks for adding
Hi Manish,
Thanks for adding some light.
395
