CME dial peer
Hi, I am trying to configure a dial peer on CME but I am getting the following error.
I_to_I_Tech_CCME(config)#dial-peer voice 1 pots
ERROR: could not add peer
Please assist
Hall of Fame Super Gold
Re: CME dial peer
That is caused by a memory leak happening on both XJ and XW versions, I've experienced this also, but had not yet the strength to raise a case about.
Reload router and you will be able to configure the DP or ephone-dn.
Re: CME dial peer
Hi, watch out if you are experiencing this.
I suspect the meory leak is more serious than I tought, as apparently has caused total failure of ISDN with "cannot expand chunk" error messages. Reboot fixed it, but I'm downgrading IOS as a precaution.
Re: CME dial peer
I rebooted the router as per your advice and it worked like magic. Thanks
155
