CME & dial plan
Hi;
How can i control the calls in CME
in CallManager i control the calls using partitions and CSS.
how can i do this in CME.
Re: CME & dial plan
There are a few options.
a. If all you need is to block calls globally, then you can setup after-hour patterns under telephony-service.
b.With CME 4.0 there is also a way to use a tcl script to force users to enter a FAC for LD, Intl calls etc.
c. Typically call routing is controlled just like in CM (Partitions and CSS) using COR Lists. Here is a good link
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
Sankar
PS: please remember to rate posts!
Bronze
Re: CME & dial plan
131
