CME / Dial Zero
I am using CME and trying to set up a dial zero action. So if any one in the business presses zero it will go to a certain extension or receptionist
Any suggestions?
i tried doing the following
voice translation-rule 100
rule 1 /0/ /1234/
voice translation-profile dial_zero
translate called 100
dial-peer voice 102 voip
translation-profile outgoing dial_zero
destination-pattern 0
1 REPLY
Re: CME / Dial Zero
you can use use "secondary " option in ephone-dn
Eg:
ephone-dn 1
number 1234 secondary 0
Or you can use "num-exp" globally
num-exp 0 1234
Hop that you are not using "0" for accssing outside line.
Bijin
393
