CME different model phones showing different time
csco11063007
He re i have a problem that my cme router having different time,7911 phone showing different time, 7941 phone showing different time..is there any way to synchrosnise the whole system.
we have only one switch whre all phones connected,one router acting as cme and gateway and ip phones..
is there any idea..
thaks in advance
2 Accepted Solutions
paolo bevilacqua
This is the field notice:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_field_notice09186a00807e9632.shtml
In short: check router configuration and upgrade phone firmware!
pacameron
Level 4
Level 4
One more thing to try, go into the telephony-service command and type 'create cnf-files' to rebuild the internal xml config files for the phones, this will ensure the time settings are same for all handsets, then do a reset all to make all handsets re-register and sync up their time. It is best to use an external NTP server for the system time, here is a config snip from a working CME that may help -
telephony-service
time-zone 48 <--- Sydney, Australia time zone
ntp server 213.157.226.100 <--- public NTP server
paolo bevilacqua
pacameron
Level 4
Level 4
telephony-service
