CME - direct incoming call from PSTN
Hi Guys,
Is there any way to direct specific incoming call from PSTN to a specific dial-peer range number on CME using COR? - 3 CMEs, only 1 cme connected to PSTN.
for example, public phone number 7771234 that originate from PSTN only allow to ring dial-peer range 7771000-7771005 on CME-A then public phone number 7771235, only allow to ring dial-peer range 7771006-7771010 on CME-C.
please advice
Thanks in advance
Hall of Fame Super Gold
Re: CME - direct incoming call from PSTN
Do you need to direct on the basis of phone line, or calling number ?
Hi, thanks for your reply...
I need to direct on the basis of calling number
thanks,
terrence
Diffrent details but same principle:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801c0a88.shtml
On the DP matrching answer-address, translate called number to desired destination.
Thanks for the links.
Do you have any documentation with COR?
Restrict outgoing call seems to be easier than incoming...
Terrence
I would use number transaltion in your case actually.
356
