Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
CME - Discard Digit
Hi All
I have CME ver 8.6, I have E1 line which last three digit are 0XX. Now the problem is if am dialing any international number its routing inside extension.
like if i dial 001 or 009 it dial internal extension. To solve this issue i configure translation rule and put that rule on dial pair but the transalation rule is not working.
when i test the rule in router its strip the digit but when call from inside to outside is not working.
below is the translation rule and dial peer
voice translation-rule 3
rule 3 /^6\(0..\)/ /\1/
voice translation-profile 3
translate calling 3
dial-peer voice 100 pots
corlist outgoing calloverseas
translation-profile outgoing 3
destination-pattern .T
port 0/0/0:15
forward-digits all
kindly help how i will do digit strip in CME.
Thank You
CME - Discard Digit
what's number you need to send ? I mean complete number?
Your translation rule will strip all number and append 0XX. which is doing rite i believe.
Br,
Nadeem Ahmed
Br, Nadeem Please rate all useful post.
CME - Discard Digit
From my local extension if i dial 006123456789 the pcall goes to extension 006
now what i did i made the translation rule if we press 6 and dial the international number it should go to PSTN.
for example if i dial from my ext 6006123456789
it should discard the digit 6 and send 00623456789
but its not happening its sending 600623456789 to PSTN.
045355: Nov 12 16:58:44.082 GMT: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x626A
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98382
                Exclusive, Channel 2
        Calling Party Number i = 0x2180, '771'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '6006185246'
045356: Nov 12 16:58:44.162 GMT: ISDN Se0/1/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0xE26A
045357: Nov 12 16:58:53.734 GMT: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x626A
        Cause i = 0x8090 - Normal call clearing
045358: Nov 12 16:58:53.870 GMT: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8  callref = 0xE26A
045359: Nov 12 16:58:53.870 GMT: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x626A
045360: Nov 12 16:58:58.082 GMT: ISDN Se0/1/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x191B
        Cause i = 0x829000000000 - Normal call clearing
CME - Discard Digit
There is config error, Please change the pattern , You are applying this translation on Calling where you want to perform this on Called number.
translate calling 3===change it to ===> translate called 3
Br,
Nadeem
221
