CME, Displaying CallerID and Station-ID
CallerID is displayed,
But Station ID is not, why?
Here is the config
voice-port 0/1/0
connection plar opx 0
description desc-1
station-id name st-1
station-id number 555
caller-id enable
Re: CME, Displaying CallerID and Station-ID
IOS will try to get caller-id first, and then station id if caller-id fails.
This means you have a calller-id error.
Try using the correct cptone for your country?
-nick
I get Caller-ID
But at the same time, I want to see Station-ID
We will only show one or the other.
This is the order the CME will choose Caller ID:
1) Caller ID (if it exists)
2) Station ID (if it exists)
3) Destination pattern on incoming pots dial peer
It's not possible to display both the caller id and station id. The station ID replaces the caller id if it does not exist.
hth,
nick
472
