Community Member
CME DN is not calling CUCM DN
Hi Voice Team,
I have a CME 2901 connected in a CUCM 8.5 via h323... I configured the voip dial peer in the cme with session ip to CUCM, but the CME DN can not call CUCM DN...
In the way CUCM DN > CME DN (ok through no ip addres trusted authenticate in voice service voip)
Could you help me please?
thanks.
Everyone's tags (1)
Community Member
Debug is bellow:
SESC_PARANAGUA#csim start 2059
SESC_PARANAGUA#
Jan 19 12:25:13.820: csim: called number = 2059, loop count = 1 ping count = 0
Jan 19 12:25:13.820: csimSetupPeer peer type(2), destPat(2059), matched(2), target()
Jan 19 12:25:13.820: //-1/xxxxxxxxxxxx/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=FALSE, Mode=0,
   Outgoing Dial-peer=100, Params=0x2B0030A0, Progress Indication=NULL(0)
Jan 19 12:25:13.820: //-1/xxxxxxxxxxxx/CCAPI/ccCheckClipClir:
   In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Calling Party Number Is User Provided
   Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Destination Pattern=[^0]...$, Called Number=2059, Digit Strip=FALSE
   Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=2059(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=FALSE,
   Guid=78C78CA4-41CF-11E1-8834-E2F049812D6D, Outgoing Dial-peer=100
Jan 19 12:25:13.820: //-1/xxxxxxxxxxxx/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=2059
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Jan 19 12:25:13.820: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x30EFB5E4, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=2059(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=100, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Jan 19 12:25:13.820: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 19 12:25:13.820: :cc_get_feature_vsa malloc success
Jan 19 12:25:13.820:  cc_get_feature_vsa count is 1
Jan 19 12:25:13.820: :FEATURE_VSA attributes are: feature_name:0,feature_time:830755000,feature_id:831
Jan 19 12:25:13.820: //831/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=0, Call Entry(Call Count On=FALSE, Incoming Call=FALSE)
Jan 19 12:25:13.820: //831/78C78CA48834/CCAPI/cc_insert_guid_pod_entry:
   Incoming=FALSE, Call Id=831
Jan 19 12:25:13.820: //831/78C78CA48834/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Jan 19 12:25:13.820: //831/78C78CA48834/CCAPI/ccCallSetContext:
   Context=0x31768D84
Jan 19 12:25:13.820: //-1/xxxxxxxxxxxx/CCAPI/cc_api_supported_data:
   data_mode=0x10082
Jan 19 12:25:13.820: //831/78C78CA48834/CCAPI/cc_incr_if_call_volume:
   Remote IP Address
   Total Call Count=1, Voip Call Count=1, MMoip Call Count=0
Jan 19 12:25:13.844: //831/78C78CA48834/CCAPI/cc_api_call_disconnected:
   Cause Value=38, Interface=0x30EFB5E4, Call Id=831
   Call Entry(Responsed=TRUE, Cause Value=38, Retry Count=0)
Jan 19 12:25:13.844: csim_do_test: cid(831), ev(12), disp(0)
Jan 19 12:25:13.844: csimTraceSct: cid(831),st(0),oldst(0)
Jan 19 12:25:13.844: csim err csimDisconnected recvd DISC cid(831)
Jan 19 12:25:13.844: //831/78C78CA48834/CCAPI/ccCallDisconnect:
   Cause Value=38, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=38)
   Start Calling Accounting;
   Call Entry(Incoming=FALSE)
   Cause Value=38, Call Entry(Disconnect Cause=38)
   Cause Value=38, Call Entry(Responsed=TRUE, Cause Value=38)
Jan 19 12:25:13.844: //831/78C78CA48834/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Jan 19 12:25:13.844: //831/78C78CA48834/CCAPI/cc_decr_if_call_volume:
   Remote IP Address
   Total Call Count=0, Voip Call Count=0, MMoip Call Count=0
Jan 19 12:25:13.844: //831/78C78CA48834/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x30EFB5E4, Tag=0x0, Call Id=831,
   Call Entry(Disconnect Cause=38, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Jan 19 12:25:13.844: //831/78C78CA48834/CCAPI/cc_delete_guid_pod_entry:
   Incoming=FALSE
Jan 19 12:25:13.844: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 19 12:25:13.844: :cc_free_feature_vsa freeing 318450B0
Jan 19 12:25:13.844:  vsacount in free is 0
Jan 19 12:25:13.844: //831/78C78CA48834/CCAPI/cc_delete_call_entry:
   Deleting profileTable[0x3178AC44]
Jan 19 12:25:13.844: csim_do_test: cid(831), ev(13), disp(0)
Jan 19 12:25:13.844: csimTraceSct: cid(831),st(2),oldst(0)
Jan 19 12:25:14.344: csim: loop = 1, failed = 1
Jan 19 12:25:14.344: csim: call attempted = 1, setup failed = 1, tone failed = 0
Jan 19 12:25:14.344: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
   ccAppShutdownMode: remove it from the queue
Hall of Fame Super Silver
Does the calling search space applied to the H.323 GW or ICT (not sure what you used) on CUCM have access to the parition of the phone you are calling?
Chris
Community Member
Yes.. On trunk h323 and Cisco route information - Inblund calls is correct..
I changed the ip address for WAN ip in the CUCM trunk and it is working...
I don´t understand...
Jean,
What IP Address were you using before as the Trunk IP Address to the h323 GW or GK? Whatever you bound under the h323 config on the CME router is the IP Address you use.
Yosh
HTH Regards, Yosh
Green
Jean
May be better if you can post the CME config.
Also what is the CUCM address as this should be in the VOIP dial peer.
The address needs to be the CUCM call processor usually a SUB.
Alex
Regards, Alex. Please rate useful posts.
Community Member
PARANAGUA#sh run
Building configuration...
Current configuration : 15584 bytes
! Last configuration change at 12:17:38 BR2011 Thu Jan 19 2012 by sescadm
! NVRAM config last updated at 19:39:40 BR2011 Wed Jan 18 2012 by sescadm
version 15.1
hostname SESC_PARANAGUA
boot-start-marker
boot-end-marker
card type e1 0 1
logging buffered 51200 warnings
enable secret 5 $1$55FF$10GbsdjhNck9kLVnONqKt1
no aaa new-model
clock timezone BRASIL -3 0
clock summer-time BR2011 date Oct 16 2011 0:00 Feb 26 2012 0:00
network-clock-participate wic 1
network-clock-select 1 E1 0/1/0
no ipv6 cef
ip source-route
ip cef
ip domain name sescpr.com.br
trunk group FXO
crypto pki trustpoint TP-self-signed-714757075
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-714757075
revocation-check none
--More--         !
crypto pki certificate chain TP-self-signed-714757075
certificate self-signed 01
  30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 37313437 35373037 35301E17 0D313230 31313732 32353430
  315A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3731 34373537
  30373530 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  BF0C85BD 83973DF9 0AD0B867 0D882F92 D21BBDEF 46987BFD 94351BA9 3A318023
  62E3E30C 7FE860C5 16F019CA E700DD2B A654211C FAA1EDD5 9894C2B8 FB7E5E9A
  5C274AA2 DD6E1A00 0F54CE6D 390EAEE8 2AAC004C 39D4B8CC 77D5AC26 1D08D07D
  C118E1CD 371A90E3 D27F5D6A 16526AD5 DAB152E7 0CE9CDD3 8825171E 257505E5
  02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
  23041830 168014DA 1185FBB6 EA837A1A 3C0C01FC BE0F20E6 11C51330 1D060355
  1D0E0416 0414DA11 85FBB6EA 837A1A3C 0C01FCBE 0F20E611 C513300D 06092A86
  4886F70D 01010405 00038181 00A4181D 6F6E9102 537E43E3 07976FE0 D4457C16
  15CA8E06 0A5ACC69 1B17D590 915C9E81 7F44CE2A FCD9AAEA E25B5CAE D823302C
  E8C6DDBA F6A59EA2 97479DE4 4447D45B 7FE8B37B 7F18B3D5 454AF866 12D01387
  757F9264 43C1025D 554524BA 8EDBBA9C A3944729 5A4DA4CA B1BE5CBB FEE33825
  EA8FB220 61ADB01B F5D27560 48
  quit
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  call preserve
sip
  registrar server expires max 600 min 60
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711alaw
codec preference 3 g711ulaw
voice class h323 1
  h225 timeout tcp establish 5
--More--         !
voice translation-rule 14
rule 1 /^000/ /0014/
rule 2 /^00/ /014/
rule 3 /^000/ /0014/
rule 4 /^00/ /014/
rule 5 /^0/ //
voice translation-profile BRASILTELECOM
translate called 14
voice translation-profile CSP-BRASILTELECOM
translate called 14
license udi pid CISCO2901/K9 sn FTX152883ZP
hw-module pvdm 0/0
username sescadm secret 5 $1$1cBF$nozYqrSpyHCUWJffRKj2/1
redundancy
controller E1 0/1/0
framing NO-CRC4
line-termination 75-ohm
ds0-group 1 timeslots 1-10 type r2-digital r2-compelled ani
cas-custom 1
  country brazil
  metering
  double-answer
  answer-signal group-b 1
  dnis-digits min 1 max 32
  ani-digits min 1 max 32
description PST-<>
interface GigabitEthernet0/0
description LAN PARANAGUA
ip address 10.105.1.1 255.255.255.0
duplex auto
speed auto
--More--         !
interface GigabitEthernet0/1
description RAV COPEL 2MB - CIRCUITO 302020
ip address 192.168.11.66 255.255.255.252
ip nbar protocol-discovery
ip flow ingress
duplex auto
speed auto
no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip flow-export version 9
ip flow-export destination 10.0.0.68 9996
ip route 0.0.0.0 0.0.0.0 192.168.11.65
control-plane
voice-port 0/0/0
trunk-group FXO
supervisory disconnect dualtone mid-call
supervisory answer dualtone sensitivity high
no battery-reversal
input gain 14
cptone BR
timeouts call-disconnect 5
timeouts wait-release 10
connection plar opx 1100
station-id name CHAMADA EXTERNA
station-id number 34233200
caller-id enable
voice-port 0/0/1
no battery-reversal
input gain 14
cptone BR
--More--          station-id name CHAMADA EXTERNA
caller-id enable
voice-port 0/0/2
no battery-reversal
input gain 14
cptone BR
shutdown
station-id name CHAMADA CELULAR
caller-id enable
voice-port 0/0/3
no battery-reversal
input gain 14
cptone BR
shutdown
caller-id enable
voice-port 0/1/0:1
cptone BR
shutdown
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 10.105.1.1 identifier 10 version 7.0
sccp
sccp ccm group 1
associate ccm 10 priority 2
associate profile 1 register mtp0021d8501180
keepalive retries 5
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
associate application SCCP
shutdown
--More--         !
dial-peer cor custom
name BASICA
name LOCAL
name CELULAR
name DDD
name PAGA
name OPERADORA
name BANCO
name DDI
dial-peer cor list LigBasica
member BASICA
dial-peer cor list LigLocal
member LOCAL
dial-peer cor list LigCelular
member CELULAR
dial-peer cor list LigDDD
member DDD
dial-peer cor list LigPaga
member PAGA
dial-peer cor list LigOperadora
member OPERADORA
dial-peer cor list LigBanco
member BANCO
dial-peer cor list LigDDI
member DDI
dial-peer cor list SerBasica
member BASICA
dial-peer cor list SerLocalFixo
member BASICA
member LOCAL
member PAGA
member OPERADORA
member BANCO
dial-peer cor list SerDDD
member BASICA
member LOCAL
member CELULAR
member DDD
--More--          member PAGA
member OPERADORA
member BANCO
dial-peer cor list SerDDI
member BASICA
member LOCAL
member CELULAR
member DDD
member PAGA
member OPERADORA
member BANCO
member DDI
dial-peer cor list SerLocalCelular
member BASICA
member LOCAL
member CELULAR
member PAGA
member OPERADORA
member BANCO
dial-peer voice 101 pots
trunkgroup FXO
corlist outgoing LigLocal
description LIGACAO LOCAL
destination-pattern 0[2-6].......
direct-inward-dial
forward-digits 9
dial-peer voice 102 pots
trunkgroup FXO
corlist outgoing LigCelular
description LOCAL CELULAR
group-name FXO
destination-pattern 0[7-9].......
direct-inward-dial
forward-digits 9
dial-peer voice 103 pots
trunkgroup FXO
corlist outgoing LigDDD
description LIGACAO DDD FIXO
translation-profile outgoing CSP-BRASILTELECOM
destination-pattern 00..[2-6].......
direct-inward-dial
forward-digits all
dial-peer voice 104 pots
trunkgroup FXO
--More--          corlist outgoing LigBasica
description LIGACAO GRATUITA
destination-pattern 00800.......
direct-inward-dial
forward-digits 12
dial-peer voice 105 pots
trunkgroup FXO
corlist outgoing LigPaga
description LIGACAO PAGA
destination-pattern 00300.......
direct-inward-dial
forward-digits 12
dial-peer voice 106 pots
trunkgroup FXO
description LIGACAO SERVICOS
destination-pattern 01[^0].
direct-inward-dial
forward-digits 4
dial-peer voice 107 pots
trunkgroup FXO
corlist outgoing LigOperadora
description OPERADORAS
destination-pattern 010...
direct-inward-dial
forward-digits 6
dial-peer voice 108 pots
trunkgroup FXO
corlist outgoing LigBanco
description SERVICO DE BANCO
destination-pattern 0078T
direct-inward-dial
forward-digits all
dial-peer voice 109 pots
description LIGACAO DDD CELULAR
destination-pattern 00..[7-9].......
direct-inward-dial
port 0/0/2
forward-digits all
dial-peer voice 110 pots
trunkgroup FXO
corlist outgoing LigDDI
description LIGACAO DDI
--More--          translation-profile outgoing CSP-BRASILTELECOM
destination-pattern 000T
direct-inward-dial
forward-digits all
dial-peer voice 300 voip
description SENAC CURITIBA
destination-pattern 4[6789]..$
session target ipv4:10.1.255.254
voice-class codec 1
dial-peer voice 301 voip
description To SENAC LONRINA
destination-pattern 50..$
session target ipv4:10.2.0.1
voice-class codec 1
dial-peer voice 302 voip
description SENAC MARINGA
destination-pattern 51..$
session target ipv4:10.3.0.1
voice-class codec 1
dial-peer voice 303 voip
description SENAC CASCAVEL
destination-pattern 52..$
session target ipv4:10.4.0.1
voice-class codec 1
dial-peer voice 304 voip
description SENAC FOZ DO IGUACU
destination-pattern 54..$
session target ipv4:10.6.0.1
voice-class codec 1
dial-peer voice 305 voip
description SENAC GUARAPUAVA
destination-pattern 55..$
session target ipv4:10.7.0.1
voice-class codec 1
dial-peer voice 306 voip
description SENAC PONTA GROSSA
destination-pattern 53..$
session target ipv4:10.8.0.1
voice-class codec 1
dial-peer voice 307 voip
description SENAC PATO BRANCO
destination-pattern 67..$
session target ipv4:10.9.0.1
--More--          voice-class codec 1
dial-peer voice 308 voip
description SENAC UMUARAMA
destination-pattern 57..$
session target ipv4:10.10.0.1
voice-class codec 1
dial-peer voice 309 voip
description SENAC CAMPO MOURAO
destination-pattern 59..$
session target ipv4:10.11.0.1
voice-class codec 1
dial-peer voice 311 voip
description SENAC PARANAVAI
destination-pattern 61..$
session target ipv4:10.13.0.1
voice-class codec 1
dial-peer voice 312 voip
description SENAC CASTRO
destination-pattern 62..$
session target ipv4:10.14.0.1
voice-class codec 1
dial-peer voice 313 voip
description SENAC TOLEDO
destination-pattern 63..$
session target ipv4:10.15.0.1
voice-class codec 1
dial-peer voice 314 voip
description SENAC FRANCISCO BELTRAO
destination-pattern 68..$
session target ipv4:10.16.0.1
voice-class codec 1
dial-peer voice 315 voip
description SENAC IRATI
destination-pattern 64..$
session target ipv4:10.17.0.1
dial-peer voice 316 voip
description SENAC JACAREZINHO
destination-pattern 65..$
session target ipv4:10.19.0.1
voice-class codec 1
dial-peer voice 317 voip
description SENAC PORTAO
--More--          destination-pattern 58..$
session target ipv4:10.20.0.1
voice-class codec 1
dial-peer voice 100 voip
description RAMAIS SESC
destination-pattern [^0]...$
session target ipv4:10.0.0.23
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
sip-ua
gatekeeper
shutdown
telephony-service
sdspfarm units 4
sdspfarm transcode sessions 5
sdspfarm tag 1 mtp0021d8501180
max-ephones 30
max-dn 50
ip source-address 10.105.1.1 port 2000
timeouts ringing 30
system message SESC - EDUCACAO PARANAGUA
cnf-file location flash:
cnf-file perphone
user-locale U3 load CME-locale-pt_BR-Portuguese-7.0.1.1.tar
network-locale PT
network-locale 1 U1
load 7942 its/term42.default.loads
time-zone 18
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
moh flash:/music-on-hold.au
transfer-system full-consult
fac standard
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template  1
softkeys idle  Redial Gpickup Cfwdall
softkeys connected  Trnsfer Park Confrn
--More--          codec g729r8
type 7911
ephone-dn  1  dual-line
number 1107
pickup-group 55
description PGA/Tecnicos
name PGA/Tecnicos
corlist incoming SerLocalFixo
ephone-dn  2  dual-line
number 1116
description PGA/Financeiro
name PGA/Financeiro
corlist incoming SerDDD
ephone-dn  3  dual-line
number 1199
pickup-group 55
description PGA/Gerencia
name PGA/Gerencia
ephone-dn  4  dual-line
number 1132
pickup-group 55
description PGA/Secretaria
name PGA/Secretaria
ephone-dn  5  dual-line
number 1133
pickup-group 55
description PGA/Biblioteca
name PGA/Biblioteca
ephone-dn  6  dual-line
number 1140
pickup-group 55
description PGA/Compras
name PGA/Compras
--More--         ephone-dn  7  dual-line
number 1148
pickup-group 55
description PGA/Ed.Infantil
name PGA/Ed.Infantil
ephone-dn  8  dual-line
number 1160
pickup-group 55
description PGA/Sl.Recep
name PGA/Sl.Recep
ephone-dn  9  dual-line
number 1184
pickup-group 55
description PGA/Almoxarif
name PGA/Almoxarif
ephone-dn  10  dual-line
number 1185
pickup-group 55
description PGA/Odonto
name PGA/Odonto
ephone-dn  11  dual-line
number 1190
pickup-group 55
description PGA/Guarita
name PGA/Guarita
ephone-dn  12  dual-line
number 1101
pickup-group 55
description PGA/SAC
name PGA/SAC
ephone-dn  13  dual-line
--More--         !
ephone  1
mac-address D0C2.8243.C8A0
ephone-template 1
codec g729r8
type 7942
button  1:3
ephone  2
mac-address DC7B.94F9.0B96
ephone-template 1
codec g729r8
type 7911
button  1:2
ephone  3
mac-address DC7B.94F9.0F71
ephone-template 1
codec g729r8
type 7911
button  1:1
ephone  4
mac-address 0025.4594.D5F5
ephone-template 1
codec g729r8
type 7911
button  1:4
ephone  5
mac-address 0025.4594.DBB5
ephone-template 1
codec g729r8
type 7911
button  1:5
ephone  6
mac-address 0025.4594.D91B
ephone-template 1
codec g729r8
type 7911
--More--          button  1:6
ephone  7
mac-address 0025.4594.D851
ephone-template 1
codec g729r8
type 7911
button  1:7
ephone  8
mac-address 0025.4594.D843
ephone-template 1
codec g729r8
type 7911
button  1:8
ephone  9
mac-address 0025.4594.D74E
ephone-template 1
codec g729r8
type 7911
button  1:9
ephone  10
mac-address 0025.4594.D6D2
ephone-template 1
codec g729r8
type 7911
button  1:10
ephone  11
mac-address 0025.4594.DC33
ephone-template 1
codec g729r8
type 7911
button  1:11
ephone  12
codec g729r8
--More--         !
ephone  13
mac-address 0025.4594.D5E9
ephone-template 1
codec g729r8
type 7911
button  1:12
banner login ^CC-----------------------------------------------------------------------
                             SESC PARANA
       Acesso restrito ao pessoal interno e autorizado do SESC-PR
     Sujeito a penalizacao vigente segundo codigo criminal Brasileiro
            Todas as conexoes sao monitoradas e gravadas
-----------------------------------------------------------------------^C
line con 0
login local
line aux 0
line vty 0 4
login local
transport input telnet
scheduler allocate 20000 1000
ntp update-calendar
ntp server 10.0.0.46
end
CUCM will only accept h225 messages from the IP you configured under H323 GW. Due to routing you might be sending another IP from the router, to control this you use this commands:
h323-gateway voip bind srcaddr ip_address
h323-gateway voip interface
This way you will bind the H323 signaling to an interface/ip address
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Community Member
Ok javalenc.. I will to applicate the command :
thanks all .
Community Member
I´M using 10.105.1.1
Jean,
Can you send the configuration of int gi 0/0 its cut out in the config you posted. You need to make sure that the h323-gateway commands are configured correctly and that the h323-gateway voip bind srcaddr ip_address is what you configured in CUCM.
Yosh
HTH Regards, Yosh
996
