CME dynamic change of calling number in outgoing calls
I have one cisco 2911 with CME 8.6 and i would like to know if is possible to configure the following:
I have one E1 connected to router with many DDI's.  So i would like every time i make an external call to PSTN i used a diferent Calling Number (random from my pool of DDI's). Is that possible to configure automatically?   I know if i dial a diferent prefix i could map a diferent calling number but this is not practice.
Any sugestions?
Best Regards
MC
The only way in which you might be able to do that would be using TCL scripting, and I'm not even sure that would be possible.
What's the idea behind sending a random calling number if you bought DIDs??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
The idea is that called people don't "remenber" the number who is calling him and answer the phone.
Unfortunetely  I couldn't configure "private" number...
Best Regards
MC
403
