Hall of Fame Super Gold
CME: Empty output from show ephone phone-load
This is the latest installation I did, and cannot understand what is preventing the versioning information to be shown with the above command. Another installation that I have is OK, and I can check the software level of the phones very easily.
Any idea ?
Re: CME: Empty output from show ephone phone-load
Are you using the same IOS version/CME versions on both installs ?
Hi Shanky,
No, they are running different versions.
The one showing the information has 12.4(4)XC4.
The other had 12.4(11)T before, now has 12.4(11)XJ. Both images fail to show the info, although the 12.4(11)T was intermittently showing info for some telephones only.
I have the same issue
any suggestions?
I 've tried
12.4(24)T1
15.0(1)M
the output of the command show
the 7921G firmware
but not
the 7971G-GE firmware
thanks
davide
Some phone FWs fail to populate that information.
Cosmetic bug without other consequences.
Bronze
Hi Davide,
I have run the command with 12.4(24)T1 and get the output without any issues with 7961s.
As mentioned, that depends by phone FW.
8.3(5S) does not show the version.
293
